Question about Dishwashers
Meiko ecostar 530F the water is not draining away. I have removed the drain hose and checked the filter. Is there another filkter or would I have to change the pump ? ty
2 Suggested Answers
whytfang
  • 170 Answers
SOURCE: i need an instruction manual for meiko ecostar 530f dishwasher
Go here and see if your manual is there...I hope this helps...thanks for rating my effort.....The Fang
http://www.meiko.us/downloads.htm
Posted on May 13, 2009
Meiko 530F leaks from doors bottom corners while washing, any hints, water level senson seems fine
Make sure the jets in the UPPER arm are all clear, and that there's no debris inside the top turret. On the bottom arm, IF the lower turret has (or is supposed to have) a rotating baffle, make sure it's in place - this looks like a very loose washer on the lower turret, running in a groove ~ the plastic versions get lost, the metal versions slip down and don't do their job.
Clean the drain channels along the bottom of the door and especially around the hinges, you will probably need a thin bottle brush or a steamer to get into the nooks and crannies.
Feb 20, 2015 | Meiko Dishwashers
Meiko manual 530f
I have a meiko 530f.
recently suddenly switching off while washing.
furthermore, the first washing cicle doesn't seems to end e any ad
Would you have any advice on that?
Thanks
Jackl'yn
Jan 03, 2014 | Dishwashers
Water not draining away
Hello, and welcome to Fixya.
To rectify your problem do the following.
Remove the lower rear panel of washer.
Locate and remove the large black hose connected to bottom of drum.
Remove and clean plastic filter inside hose.
Reassemble and test for leaks.
Check drain hose for blockage if it still does not drain.
Feb 10, 2011 | Hotpoint WM56 Front Load Washer
My dishwasher doesnt drain away
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jan 01, 2011 | Dishwashers
My bosch SGS3062GB is not draining the water away - the water is stagnent in the bottom of the dishwasher. I ran the rinse cycle and it left about 2.5inches on water in the bottom of the...
Hi
Daniel
Dec 13, 2010 | Dishwashers
It won't pump out the water.
Hi
Oct 25, 2010 | Frigidaire Dishwashers
"OE" message
OE is actually DE - Drain Error. Pop open the little door on the bottom left of your washer, and unscrew the cap on the little tube on the left. ***Water will drain out!***
Once the water is out, unscrew the bigger tube on the right. This holds your drain filter. It is likely clogged, so clean it out and reinstall the filter and cap from the small hose.
Hopefully this fixes it!
May 02, 2010 | LG WM-2277HW Front Load Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
I need an instruction manual for meiko ecostar 530f dishwasher
Mar 30, 2009 | Meiko DV 80.2 Dishwasher
Dishwashers Logo
160 people viewed this question
Top Dishwashers Experts
