SOURCE: repeat keys and back space has pause when typing
I fixed it by completely restoring my computer...thanks for your help...
SOURCE: keyboard issues
a bad chip in the keyboard usually causes this problem. Replacing your keyboard with a new one is the thing to do
SOURCE: Navman Tracker 5500 turns on but locks itself in the entry page
Apparently it is the internal battery that might be at fault or just be old. I'm going to replace mine as it costs a fortune to get Navman to do it. Can't find any info on how to do it, but should be simple. Only thing is that you lose all waypoints and other user input data (unless you have the PC Planner from C-Map).
SOURCE: Wireless keyboard problem
just called Logitech support (who were more than helpful, very friendly, and picked up the phone within 5 minutes).
I have an MX3000 laser combo set and the receiver lost connection to the mouse last week. Then the keyboard went out a few nights ago. I had tried what everyone else here had tried to no avail.
So I decided to give a tech support line the benefit of the doubt and call one...
I'm very glad I did!
Here is the entire process for the Left Ctrl + Left Alt + F12 keys. First, when you hit these keys together, a box should pop up on screen to prompt you to reset the encryption sequence. That is what these keys are for. If nothing pops up on your screen (as was my case!), wait a few minutes for the button sequenece to time out, then hit these keys again. Make sure its L-Ctrl + L-Alt + F12 only. Within 2 seconds after that button combo, hit connect on the receiver. Within 2 seconds of that hit connect on the underside of the keyboard. Within 2 seconds of that, hit your Escape key on the keyboard. Sounds completely ridiculous, but this is the direction Logitech support drove me in. And it worked for me. And this is after I tried everything imaginable for over the past week.
We then moved on to the mouse, which i thought we had fixed. But now i have one working and one not working, so I think I need to re-run through this whole process to fix the second mouse. Basically, I now have 1 mouse that works on both receivers, on 2 different pc's with 2 different keyboards in two different rooms (both sets are MX3000 however).
The other now seems to have lost the signal. Will update if I get that second mouse to play nicely with me.
Hope this helps anyone about to trash a perfectly good unit like I was!
SOURCE: Browser keeps reloading last page
Bring up your Browser, click on tools and then Options. When the Options comes up in the Start with page, will read "Show my windows and Tabs from last time" and click on the drop down and select "Show a Blank Page." Then it should work okay. Hope this helps. Bud
netgear wireless, first thing we need to make sure is that we are connected hardwired to the router. after ensuring that we are connected. try to open a browser, be it internet explorer or mozilla firefox.
after you have the browser on your screen try to go to the address bar and type in there 192.168.1.1 the username is always "admin" all in lower case, and the password is the word " password " itself. all in lowercase. after successfully accessing the netgear page, try to check the leftside of the screen and look for wireless settings. and click on it. then look for network name, type in, or create your own network name there. next is look for security options. and make sure to choose WPA-AES(TKIP) after choosing it. type in your passphrase now on the box below it. make sure its 8 characters and longer. then click on apply settings. this would take a couple of minutes. after its done applying the settings, exit from that screen and try to locate your network name and connect. this should work
