Question about GE WBSR3140DW Top Load Washer
My Washing Machine, GE, WLSR3000G, will fill and drain, but will not spin or agitate, what do I need to do to fix it.
jumptrout51
  • 3361 Answers
SOURCE: GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Posted on Mar 21, 2009
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
SOURCE: GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Posted on Apr 15, 2009
  • 235 Answers
SOURCE: 1.5 year old ge profile washing machine will not agitate or spin
Timer seems to have gone bad. Manually move the timer to make the dryer spin. If you get it to spin and drain then it's your timer.
Posted on Jul 01, 2009
SOURCE: GE Washer WJSR2080V3WW will fill, spin and drain but not agitate.
The problem is the agitator coupler (about $ 7.00) simply pull straight up on the agitator - Give it a good tug. take the one bolt holding the coupler off - pull straight off. Replace the coupler and bolt (they are sold together). Line the agitator lines up with the coupler lines - when they line up it should go all the way down and snap back into place. and your done.
Posted on Oct 02, 2010
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
My GE WCSR4170D AWW top loading washing machine will not stop filling with water. i can get it to agitate when i blow into the air line hose attached to the water level switch. BUT it never stops filling...
Thanks for choosing FixYa and welcome. You probably have a bad water level switch. As for the agitation, the drive motor controls the agitation, spinning, and draining. It is possible for the machine to not agitate, but yet spin and drain. The motor runs clockwise and counterclockwise. It may be bad and if so, will need changed.
Apr 30, 2011 | General Electric WCSR4170D Top Load Washer
My GE washing Machine will fill with water and agitate but will not spin or drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 06, 2011 | GE Washing Machines
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Jul 01, 2009 | GE WDSR2080D Top Load Washer
Washer won't wash
Hi!
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | GE Washing Machines
No spin or agatae
Unplug machine. Change load type to medium. Clean door sensor. Set knob to drain and spin. Plug machine back in to powr. Open and close door 10 times in 15 seconds. Pull knob to activate drain and spin.
Mar 19, 2009 | General Electric WHDSR316G Top Load Washer
GE WBSR3140DW Top Load Washer Logo
75 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
