Question about Sony BDP-S300 Blu-Ray Disc Player
My Sony Blue Ray has been updated with the lastest firmware yet I still get UNKNOWN or No disc when I load ANY disc.It will eventually work if I eject and reload several times.Help??
  • Sony Master
  • 6,771 Answers
If you can play standard dvd movies without a problem, then you are looking at a laser pickup assembly issue. The blue ray disc require more precision to provide the higher resolution when it is demanded, this is an early indicator of impending failure in the assembly. However there is a small chance that cleaning the laser pickup lens may solve the problem but unlikely.
Posted on Dec 29, 2010
Testimonial: "Thanks for the quick response, I will see if cleaning helps first. Greg,Texas"
Blue ray dvd does not play blue ray movies. It will play regular dvd
In most cases, the issue might be with the Java contents on the new Blu-ray discs is making this issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is). Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
Please click the following link to get the latest firmware update available for your Blu-ray Player:
You can enter the model # of your Blu-ray Player to download the firmware update for your player.
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DRIVER
You can review the "Important Notes" and "Firmware Update Instructions" on the page to get the instructions to install the firmware update.
If the issue persists after installing the firmware update, the would have been with the disc. Check the disc with another player, try different discs with same player.
If the Blu-ray Player is not at all playing any Blu-ray disc, then it may require service.
Jan 15, 2011 | Sony Televison & Video
Message reads " unknown disc"
It sounds like your player needs a new firmware update; not to worry this is easy and keeps your player up to date with changing software technology for blu-ray discs.
Go to http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6154&os_id=99&mdl=BDPS550
At this location you can download the update and burn it to a disc that you insert in the player. The player will then do everything automatically that is required to get you the newest update made by Sony.
If however you do not have the ability to make this disc, navigate that same page for simple instructions on how to get a disc for free from Sony that has your update on it already. They ship to you pretty quickly and for free as well.
There are also software updates as well but probably do not pertain your problem but could be needed in the future. Here is the user manual.
Check page 54. http://www.docs.sony.com/release/BDPS550_US.pdf
Nov 01, 2010 | Sony BDP-S550 Blu-Ray Player
I can't get my blue ray player to play Avatar Blue Ray dvd. I loaded the disc and the player shows 0.00.00.00 but won't advance. I pressed play and play showed on the player then menu appeared. Menu still...
Like Kelt67 said a firmware is needed....Avatar holds a lot of memory on the blu ray disc as that's one reason there are no trailers just strictly the movie and that's it on the blu ray....Avatar works perfectly fine in my PS3 but then my fiance tried watching on a regular Sony blu ray player and it just sits and loads forever....needs a firmware upgrade need to pop the firmware disc in and download by contacting your blu ray manufacture if no ethernet port on your blu ray player.
Apr 22, 2010 | Sony BDP-S300 Blu-Ray Disc Player
My sony blue ray wont play hd movies.
Does your player load the blu-ray menus?
Mine wouldn't until I updated it's firmware.
You can find the firmware upgrade for Sony BDP-S300 players here.
I hope that helps.
Oct 07, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Sony BDP-S300 Loading problem
I had same problem. Solved by updating firmware:
Here is the url for the latest Firmware and instructions to install it.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4320&mdl=BDPS300
May 26, 2009 | Sony BDP-S300 Blu-Ray Disc Player
purchase a DVD cleaning disk wipe it with rubbing alcohol insert it and, let it play this will clean the laser
May 20, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Blue-ray disc causing Sony blue-ray player to shutdown
No memory issue check on Sony's Website for Firmware update for your specific model and doenload and update your player
Nov 25, 2008 | Televison & Video
Blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
Nov 22, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Ps3 blue ray error code
hi thousands of people are having this problem including me. i phoned sony on saturday and they told me a patch was coming out tomorrow(8thjan) to fix this disc loading problem. hope this helps you
Jan 07, 2008 | Sony Playstation 3 (PS3) Console
Sony BDP-S300 Blu-Ray Disc Player Logo
868 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
