Question about Fahrenheat F2543 Baseboard Heater
Wired in five baseboard heaters 240v with controls FTA2a no heat
galaxian
  • 14 Answers
SOURCE: wiring for baseboard heater
I hope you are using a Line Voltage Thermostat!! First, make sure that the power feeding the thermostat is coming from a two pole breaker of the correct amperage (20 amp). If you are using 12-2 wire with ground then please mark the white wire with black tape at each end to identify it as a HOT power source and not a Neutral wire (which is a grounded lead). Do the same for the 12-2 wires feeding the baseboard heater from the Line Voltage Thermostat. The wires from the thermostat (One Black & one White w/black tape) will be wired to each one of the two wires (one Black & one Red or two Black wires) at the baseboard heater. It doesn't matter which wire from the thermostat is wired to which wire at the heater, just as long as there is one wire to one and one wire to the other.(eg. Black from stat to Black at heater/White w/blk. tape from stat to Red at heater OR Black from stat to Black at heater/White w/blk. tape from stat to OTHER Black at heater). I have seen baseboard heaters with two black wires or one black and one red wire. Hope this helps, but if you are confused then please have an experienced tech. do it for you.
Posted on Dec 14, 2008
  • 92 Answers
SOURCE: dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Posted on Feb 24, 2009
  • 252 Answers
SOURCE: I have 2-240V (4.2V) basebaord heaters, Need Wiring Diagram
nothing wrong w/ 10/3 @ 20A. use the red and black and don't use the white. dosent matter which is which (blk and red).
Posted on Mar 22, 2009
  • 10865 Answers
SOURCE: I'm replacing a non-hydronic electric baseboard
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Posted on Jan 06, 2010
Testimonial: "Excellent Reponse"
  • 4 Answers
SOURCE: please i need help with 240v wiring to heater
i have the answer, i just did mine...though u already have your answer since this post was published a while back ago...if not write me back...
Posted on Nov 07, 2010
How do i wire a baseboard heater
therte is no neutral wire when wiring 240v ( 2 black 1 ground usually)
Sep 20, 2014 | Fahrenheat Electric Convector Baseboard...
I need to wire a remote thermostat to my electric wall heater in the bathroom. Not sure if I run the wire from the panel to the heater first or to the remote thermostat then the heater.
Run the wire to the thermostat then to the heater
BASEBOARD WIRING WITH A SINGLE POLE (2 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLY
BASEBOARD WIRING WITH A DOUBLE POLE (4 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLYdennis675_0.gif
Jun 21, 2011 | Heating & Cooling
Looking for a wiring diagram for a fahrenhear model FTA2a
I found this VERY helpful step-by-step pictorial direct from Marley (manufacturers of the heater and thermostat).
Worked like a charm for me.
www.marleymeh.com/en/assets/pdf/F2500wiring.pdf
Nov 21, 2010 | Fahrenheat Built-In Baseboard Thermostat...
Heat
What is it that you are trying to do? Do you have a piece of hot water baseboard heater and you want to 'power' it with an electric hot water heater?
Codes aside, I don't see why it would not work. You will have to put a circulator (and a temp control device) on it to move the water.
This is not going to be a very economical heating system.
Feb 05, 2010 | Marley Electric Hydronic Baseboard Heater,...
Where do i connect load wires to 240 volt baseboard heater
this is tricky to some you must connect heater to the load side of thermostat must will have a black set and a red set wires look at the directions to find the line side which you hook wires from panel to them I will tell you some switches are different so with out seeing the schmatics its hard to tell you email me a picof thomastat and i can tell you hope this helps
Oct 27, 2009 | Dayton Electric Heater
I want to install 240v baseboard htrs in a below ground basement.
you must really love your hydro co
those heaters are a huge draw on your bill
why not install radiant heat they are cheep now in compairison
the unit is a central mount run the line in a loop arround basement and conect all the heaters in drop lines off the main line small thermostat valve for each room to control heat
cost is more for unit but savings are greater too they now make a light duty units designed for your porpose
single direct electric heaters are pigs on the hydro bell if you have gas or electric it is cheeper to run a small boiler or heat on demand system
Aug 04, 2009 | Heating & Cooling
Electric baseboard heaters
measure the room, then multiply the length by the width to get the square feet you want to heat. multiply this by 10 and that is the watts you need to heat the room assuming you are using standard 220/240v baseboards.
Dec 25, 2008 | Marley Electric Hydronic Baseboard Heater,...
Farenheat baseboard heater F2544
I just had the same problem last night. Wire the two red wires from the thermostat to the power source from the service panel. The remaining two black wires from the thermostat connect to the heater.
Oct 20, 2008 | Fahrenheat Electric Convector Baseboard...
Baseboard heaters
measure each room you want to heat. multiply the length x width, this will give you the square footage of the room to be heated, multiply that by 10 and that is the number of watts needed to heat the room using 220/240v baseboards.
Sep 11, 2008 | Fahrenheat PHH15002 Oil Filled Baseboard...
Fahrenheat F2543 Baseboard Heater Logo
42 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
