Question about Black & Decker Garden
My new Black and Decker electric chainsaw worked for about 20 minutes then refused to go. I've checked everything, changed the fuse etc but nothing. I'm sure it didn't overheat. The trigger switch seems quite stiff (feels cheap) but it goes all the way in. Any suggestions before I return it to the shop?
    Brigadier General:
  • 4,088 Answers
Does the switch have a 'click' when pulled? Make sure the power didn't fail by trying it in a different circuit (or test the one you are using with a working lamp). Other than that, I'd return it for repair or replacement. Good luck!
Posted on Dec 29, 2010
How to repair a chainsaw
your clutch springs are weak. replace springs or clutch assembly
Jul 17, 2014 | Black and Decker USA BLACK & DECKER...
Black and decker user manual for electric chainsaw
Hi Margaret
Hope this helps you.
Go to the following webpage and download the user manual for your chainsaw
You can find PDF manuals in their parts and service website. Just search by the product SKU number.
Once you pull up the product, you'll see a manual link to the right hand side. http://www.blackanddecker.com/Parts.aspx
Bud
Mar 05, 2013 | Black and Decker USA BLACK & DECKER...
I am not sure whether my question got posted or not. I have a 19' electric Black and Decker lawn mower and I recently replace dthe 681064-01N switch. After replacing it, the mower worked for about...
is there a reset on the motor itself ! the motor maybe getting hot and shutting down. will it start after a few minutes. if its running hot, clean out motor because it sounds like it is running hot. repost if need be.
Oct 28, 2011 | Black & Decker 19" Electric Lawnhog...
I have a 1600w electric black & decker chainsaw recently purchased that simply takes forever to cut the smallest of logs. Is this the norm?
Hi there Bugs,
Definitely not the norm. I'm guessing that although it was recently purchased, it was used?
It will either need a new chain or have the old one professionally sharpened. You didn't mention bar size, but a new chain should be between $18-30.00.
A less expensive alternative would be a small engine repair shop that services chainsaws. Most also have reconditioned chains for sale.
Eight days ago I picked up a 19" bar banana bar and used chain for $15.00 total to finish some oak. It Rocks.
Try the chain change. Difference? Night and Day.
Best regards
Mike
Jul 30, 2010 | Black & Decker Garden
Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Will not start at all . lots of compression. new plug. crankcase full of stale fuel, flushed and still not starting
Put a little gas directly in the carb and try and start it,If it starts for a second,Clean the carb and check for holes or crack in the hoses,Replace if needed.
May 06, 2009 | Husqvarna Chain Saw 20" Bar
Unit began smoking and smelled hot
If this was a recent purchase for which you have a receipt, return it to the store immediately while you still can. If it is beyond the store's return policy, but purchased less than one year ago (most times you will still need a receipt), call Black and Decker to get in-warranty service/replacement.
In fact, call Black and Decker anyways - if the BL5000 was manufactured between Dec.2003 and Jan.2005 (highly possible if it was marked on clearance), the blade assemblies were recalled. here is the recall notice:
http://www.blackanddeckerappliances.net/safetyrecall2.html
If it is out of warranty, let the blender cool for an hour. Then remove the blender jar, plug in the base, and see if it will spin with nothing attached to it. See if it smokes if left on for 1 full minute - don't let it run longer than one minute.
If it doesn't smoke, let it cool for an additional 20 minutes. Then remove and then reassemble the blade assembly, gasket, etc., collar, jar, etc. Try blending. If it smokes while blending, order a new blade assembly and gasket (usually they come packaged together - around $20 or so). Once the new blade assembly/gasket arrives, try blending again. If it doesn't smoke, you're probably good to go. If it does smoke, you have a more serious issue.
All of this is going to take time and money if it is out-of-warranty. If you have deemed that the blender is worth more than $50 for a new one, let me know.
Mar 26, 2009 | Black & Decker BL5000 ProBlend Work Top...
Garden Logo
104 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
