Question about D-Link AirSpot DSA-3200 (F56772) Firewall
I've forgotten the username and password for my router. The router I have is the DSA-3200. Airport wireless G public/private gateway. Is there any way I can reset the password to default
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Dec 29, 2010
I have forgotten my username and password
usually underneath the router will contain a password and username if there is none there or if it's been changed. You can always contact your ISP as they will be able to configure it and/or give you your current username and password.
Dec 18, 2013 | Gateway Wireless-B Router (wbr-100)
Tip
How to configure a Router?
How to determine the WAN configuration or Interntet configuration of a SOHO Router?
1. Connect the computer to the Modem via Ethernet cable. Make sure you are able to going online 2. After confirming you are online. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway
There are 4 possibilities of IP address you can get
i)Public IP address under PPP adapter. -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP ii) Public IP address under PPP adapter and Private IP address under Ethernet adapter -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP iii)Public IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Click Mac clone on the router's WAN configuration * Power-cycle modem and Router. iv)Just a Private IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Power-cycle Modem and router.
After determining the WAN mode, it is time to configure the Router
1. Connect the Modem to the WAN port of the router. Connect the computer to the LAN port 2. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway. The Default Gateway will the IP address of your router 5. Open a Web browser and type http://192.168.1.1(where this is the default IP of the router. This will be different from each manufacturer) on the address bar. 6. Go to WAN settings or Internet settings and select the options based on the above mentioned possibilities
on Aug 26, 2010 | Computers & Internet
WIRELESS GATEWAY
How to View or Change Your Wireless Network Password
Symptoms:
You have lost or forgotten the password to your wireless network
You have lost or forgotten the password for the router, access point or other network device
You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
Launch your Internet browser and type http://www.routerlogin.net in or http://192.168.1.1 or http://192.168.0.1 the address field for your browser. Enter the router's username and password.
The default username is admin, the default password is password.
From the left-hand navigation menu of the Router administration interface, select Set Up > Wireless Settings
Note: On some routers this option will be under BASIC > Wireless.
From the center screen, you find the current wireless security settings under the Security Options heading.
If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Read more about Securing your Wireless Network.
If you cannot log into your router:
- If you were routed to the NETGEAR website or getting the "Page cannot be displayed" message when trying to login to router, make sure you are connected to the NETGEAR router. Check your wired connection and make sure cable is securely plugged in and LED is on. If wireless adapter is on, make sure you are NOT connected on a different wireless network.
- Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default access information to reconfigure your router settings. NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
Secure Your Wireless Network: WPA/WPA2 (Recommended)
Reset and Restore a NETGEAR device to Factory Default Settings
Default Password for NETGEAR devices
Jul 19, 2012 | Gateway Computers & Internet
Linksys password recovery
Computer Hope does not assist users in bypassing this security measure. If this is your router and you've forgotten the username or password we suggest that the router be hard reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com.
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Dec 21, 2011 | Linksys Wireless-G WRT54G Router
I need to find security key or passphrase for my linksys wrt54g
If it's a new router OR If you forgot the password you can follow the given solution. If you've also forgotten the default username and password then on the back of the router you will find a pinhole for resetting. Disconnect all cables from the router except the power. Put a pin in the hole and hold it there till all lights goes off and comes back on again. Then follow the steps mentioned below.
Click on Start - Click on Run
Type "CMD" - Click on OK
Type IPConfig and hit Enter on the black CMD screen
You will get the IP address and default gateway. Write down the default gateway and close the CMD window.
Goto Internet Explorer or the browser you are using. Enter the default gateway on the address bar and press enter. You will get a window to type user name and password. You can use the default username and password as given below if you have not changed it.
Default username = admin
Default password = admin
Click on the wireless tab as highlighted in the image below
Click on wireless security as highlighted below
Click on the drop down of security mode (1) and select WPA or your desireable security then type the passphrase in the box (2) and click on save changes.
Disconnect the ethernet cable and try to go wireless and put the passphrase you typed on the router page.
Regards,
Shrey
May 30, 2011 | Linksys Wireless-G WRT54G Router
Upluged router to move it and lost "Secure"
Welcome to fixya
Please follow the steps to make the wireless network private
Click the below link
http://192.168.1.1
Now it will ask for username and password
Enter username = ( blank) and password = admin
If you can't login using this credentials then you will have to reset the router
If you logged in . Then click on Wireless > Wireless security
On this screen select
Security Mode : WPA Personal
WPA Algorithm : TKIP
WPA shard Key : "enter a password here"
Group Key Renewal : set to default
Click on save settings. After that restart router .
Now your wireless network is secured and you will have to type the WPA shared key inorder to connect to router when it prompts
Thanks
Vote me if you find my suggestion helpful
Apr 25, 2011 | Linksys Wireless-G WRT54G Router
Hi. How do I change my public network to a private one without knowing the password?
you need to set a password and this has to be done using the router web interface (192.168.1.X) find the default gateway of you computer - run ipconfig on command prompt will let you know the defaukt gatway - once you are loged in to that web interface - go to wireless section and enable the security as need - this will make your network as private.
router Web interface can be opened by typing just the default gateway on address bar of IE .
Oct 04, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Forgotten password and cant get connected to ipod
Log into the router page not sure of exact make and model of router but if you do the following on a PC
start>run (search box on vista/7) > CMD > ipconfig /all look at the default gateway - should be something like 192.168.0.1 now use that number in an Internet explorer address bar - should give you the router login often the default username and password is admin - but that does vary by make and model then under wireless section you should be able to read the password for wireless OR
it may be that the password is actually printed on the bottom of the router
Mar 20, 2010 | Belkin N1 Wireless-N Wireless Router
D-Link DSA-3200 Gateway/Router and Access Points
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
Jan 08, 2009 | D-Link Airspot (DSA-3200) Router (DSA3200)
Password
Forgotten your password
Press the Reset button for about 10 seconds to reset the router to the defaults,
then use the default user name and password (admin and admin) to access the
Gateway Wireless Router Setup utility.
Usually the default password is found on the bottom of the router .You can find number below the SN bar code.
Jan 03, 2009 | Gateway Wireless-B Router (wbr-100)
D-Link AirSpot DSA-3200 (F56772) Firewall Logo
239 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
