Question about KitchenAid Washing Machines
Agitator is frozen but motor and transmission are movable by hand
  • dbennet6 Dec 29, 2010
    It's model KAWS700JQO
    Model KAWS700JQO
  • 4,323 Answers
Hi
It really depends on the model no that what is wrong, please post back with the complete model no.
Daniel
Posted on Dec 29, 2010
  • Daniel Scott
    Daniel Scott Dec 29, 2010
    If the agitator is frozen then take it apart and clean it.
    After this is done inspect part#3 which is the clothes mover and part#5 which
    is outer tub ring & seal and the part that is bad should be replaced. Hope this helps...please post back for further
    assistance.
    "Times New Roman";mso-ansi-language:EN-US;mso-fareast-language:EN-US;
    mso-bidi-language:AR-SA">Daniel
    After this is done inspect part#3 which is the clothes mover and part#5 which is outer tub ring & seal and the part that is bad should be replaced. Hope this helps...please post back for further assistance.
    Daniel
Kenmore 110.24622300 won't spin, agitate or drain but fills
There is a coupling between the motor and the transmission for the agitator that is made of plastic and rubber. The plastic gets brittle and cracks, so it will not agitate anymore. The hum you hear is probably the motor spinning without driving anything. The pump to drain the water is also driven by the same motor. If you go online you can find instructions for how to replace the coupling. You can order them from Amazon, I found one for mine for less than $5.00. This is the most likely suspect. If you are mechanically inclined, you can replace it yourself. If not, a repairman can do it relatively quickly, but there will be a hefty charge for a service call and the labor rate it high.
Dec 12, 2013 | Washing Machines
Washer only makes a humming noise
HI,
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Oct 04, 2008 | Kenmore Washing Machines
Maytag Performa washer drum turns with agitator. Also the brake doesn't stop the drum at end of cycle or when cover lifted.
The first thing to check is the clutch. It's supposed to lock the inner tub and drive the transmission (agitator) when the motor turns in one direction, and spin the tub when the motor turns in the other direction. It's also possible the agitator drive shaft coming out of the transmission and the concentric tub drive shaft are frozen together (worst case) - this is usually caused by a bad bearing seal allowing water to leak into the shaft.
Lifting the lid during the spin cycle should disconnect power to the motor - maybe what you see is the tub continuing to spin because the transmission is acting as a flywheel. Either that, or the lid switch actuator is not working properly.
Nov 27, 2010 | Washing Machines
My Frigidaire Gallery Model #GLWS1339CS1 will not agitate. It fills, drains and spins okay and at the proper time. When the machine hits the agitation cycle, I can see the agitator engage, but it doesn't...
It doesn't agitate
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Nov 27, 2009 | Frigidaire Washing Machines
Washer won't spin or agitate
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Apr 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Spin Cycle (again) on Whirlpool Washer - Bad Noise
then the transmission is bad the part number is 3360629 since you know about the drive coupling the you know wher the transmission is all you need to do to change it is
remove the agaitator
move pump to the side
drop dow the motor
remove motor wiring at switch
remove the retaing clip from the transmission for the motor wiring
the tranny is held in place with 3 half inch headed bolts
reinstall backwards and you are good to go
Apr 16, 2008 | Whirlpool LSQ9610L Top Load Washer
Pav2200 model
Sounds like a transmission problem. It's locked in agitation mode. When it is in agitation mode you can't turn the drum or move the agitator. I'd check that out.
Jan 17, 2008 | Maytag PAV2300 Top Load Washer
Whirlpool Washing Machine Top Load LSC9355AN0 agitator frozen
Had the same problem, just hade to replace the agitator.there are teeth on it and it was stripped out.
Nov 13, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not agitate but will spin
You are correct that motor turns one direction for agitate and the other for spin. The problem you describe sounds serious but there is a chance it is not. First, try to turn the transmission by hand. If it wont turn by hand, remove the agitator and see if something has gotten under it and has it locked to the basket. To remove the agitator, pop off the top cap and look down inside. You will see the bolt that holds the agitator on. After you take it loose the agitator will slide off.
If there is nothing there, the transmission will need to be replaced. If the washer is less than 5 years old, the transmission may still be covered by warranty. Check your owners manual for warranty details. Post back to let me know what you find out.
Oct 21, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Washing Machines Logo
128 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
