Question about Yamaha RX-V1700 Receiver
My yamaha rxv 1700 7.1 ch amplifier with defenite speakers shuts of at 40% of volume it gives a the option check the wiring how to solve this problem
    Guru:
  • 2,178 Answers
Open the unit and inspect for cold solder connections. Use a non-conductive tool to poke the circuit board for the bad connection. Please keep in mind that when you do this, the unit has to be powered up - be cautious of the live circuit.
Posted on Dec 29, 2010
Yamaha home theatre system RXV 350 amplifier
Check it without speaker connection. If the set does not go to protection mode, check all the speakers by connecting one by one at a time and switch the set ON; to find the faulty speaker. If the set goes to protection mode even no speaker connected, check and replace damaged components at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Yamaha RXV-350 Receiver
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
YAMAHA RXV 350 Right Speaker not Working
The amplifier for this channel is NOT working.
Feb 09, 2012 | Yamaha RXV-350 Receiver
YAMAHA RXV350 RIGHT CHANNEL NOT WORKING
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
Jan 26, 2012 | Yamaha RXV-350 Receiver
SYSTEM SHOWS ERROR CODE PROT AND SHUTS DOWN
Check the impedance (resistance) on all the speakers and the speaker wires themselves.
Power up the unit with no speakers or inputs attached at minimum volume and see if it still goes into protection mode.
Most speakers should measure between 4 and 8 ohms for most systems when disconnected from the receiver.
If the unit says PROT even with no inputs at minimum volume with the speakers detached, then there's a problem with the amplifier itself, probably in the output section.
Jun 12, 2011 | Samsung 1000W 5.1-Ch. Home Theater System...
14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
May 10, 2010 | Yamaha P2500S Amplifier
Pushing 4 ohm speaker systems
Officially this receiver supports only 6 and 8 ohm speakers. But for surround speakers it should not do any harm, because they are not played at full volume. But be sure to set yamaha for 6 ohm speakers.
Using only 4 ohm speakers makes the amplifier work more hard and produce more heat, that's why you can't use it at high volume.
Nov 30, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Rxv-520
Hello, it is worth checking that there is adequate ventillation around the unit, especially if it is in a cabinet. Also check that there is no dust clogging the vents on the unit. Another cause for overheating is using speakers that require far more power than your receiver can provide, or speakers with an ohm rating that is lower than the amplifier provides. Also, check to see if any wires to the speakers are crossing over as shorting will cause the amplifier to overheat and cut out. Hope this helps.
Jul 26, 2009 | Yamaha RX-V520
Need to connect tv, satelite and dvd to yamaha rxv1700 receiver
hello i think the question is how to connect two equipment (dvd and directv) your tv has video 1 video2 aux, put one at any input and the sounds out from tv go to receiver inputs,this way you listen what is on tv in your amplifier....................saludos
Nov 24, 2008 | Yamaha RX-V659 Receiver
Yamaha rxv 595 receiver shuts down when volume is increased
THE SPEAKER WIRES ARE REVERSED.... On the receiver the red side is always positive and black is always negative.
change + to - or
change - to + on one or more speakers.
positive side--------------------negative side
red --------------------------------black wire
gold wirew/silver--------------silver wirew/gold
white lined----------------------non-white lined
Oct 30, 2008 | Yamaha HTR-5730 Receiver
Yamaha RX-V1700 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
