Question about Garmin GPS
Garmin gps III / internal battery replacement
  • Anonymous Aug 10, 2008
    How do I replace the internal battery of a Garmin GPS Pilot III
  • Anonymous Feb 25, 2009
    how do i open it
March 2009 I replaced the solder type battery of my GPS III Plus with a battery holder (clip) that a “Basic CR or BR2032 Coin type battery”, without solder connections, that is, they simply clip into place. Replacement batteries can be purchased at less than a $1.00 of E-Bay.
Posted on Mar 09, 2009
5 Suggested Answers
SOURCE: need to replace memor4y battery
I have the same problem. how can I get it fixed?
Posted on Oct 11, 2008
  • 3 Answers
SOURCE: Replacement Memory Battery
I dont have a GPS 111 plus unit but my guess is that it has a very small solder in 3v rechargeable lithium battery (as do most Garmin units)
This is a $1 quick and dirty fix which I have used for the i2, i3 and i5 series and could probably be adapted for the GPS111.
Forget all about the 'special' battery, just get a CR2025 or similar 3v lithium button cell. make it 'wire ended' by baring off the ends of some very thin connecting wire say 2 inches long and tape to each side of the battery with insulating tape. Slacken the 3 screws holding the AA battery pack and tuck the CR2025 underneath, pack some sponge on top so that when the screws are re-tightened there is sufficient pressure to keep the battery firmly in place and also to keep the wires held firmly against the battery. Remove the original button cell and wire in the new CR2025 make sure you keep the same polarity. Thats it.
I know the CR2025 is not chargeable but it does not need to be, its capacity is about 100 times greater than than the original cell and it will last at least 5 years without becoming discharged, it is not affected by the tiny charge current the garmin tries to put in it. The original button cell will have failed within about 5 yrs so it's a 'no brainer'. This solution is intended for folks with some electronic knowledge and ability, If you do not fully understand any of the above then dont attempt it'
Hope this helps.
Posted on May 23, 2008
  • 59 Answers
SOURCE: garmin gps 95xl battery
The battery is a Panasonic VL1220. See my local post here about replacement.
Posted on Apr 25, 2009
  • 10515 Answers
SOURCE: Can i replace a Pilot
You cannot replace the internal battery on this unit yourself.You need to contact Garmin for the same.Most of their GPS's are hermetically sealed and positively pressurized by Nitrogen. Stops internal corrosion and makes them truly waterproof. You have to break the seals to take it apart, and then re-gas it.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 20, 2010
How can i get a replacement memory battery for garmin gps-75?
FDK ML621 TZ1 Battery
Garmin GPS Internal Battery
The link above has info on the battery replacement. You can do a search for the battery using the battery number.
May 29, 2014 | Garmin GPS
What type of batteries are inside the Garmin Streetpilot GPS. Mine will not take a charge any longer
depending on the model of streetpilot. The Streetpilot III has 6 AA batteries, 2600, 2700 & 2800 series have no internal batteries. the C300 and C500 series have an internal battery that is not easily replaceable.
Oct 29, 2009 | Garmin StreetPilot C330 GPS Receiver
GPS III Pilot? will not power up
Try the dc plug too (also make sure the battery connections are good in the caste). IF still no power up, the internal battery may be shorted. Lots of info online for replacing the internal battery. Good Luck!
Sep 13, 2009 | Garmin GPS III
Have a garmin gps3 that will not power up - batteries checked OK. gps hasn't been used for a couple of years. replaced batteries with new - no go
IF it stil won't pwer up with the dc plug, I suspect the internal battery. Lots of info online on replacement, you can CAREFULLY snip one lead as a a diagnostic test to take it out of the circuit. Good Luck!
Sep 07, 2009 | Garmin GPS III
Dont want to turn on
IF the internal battery is dead, which happens, it will no turn on even with good batteries or the DC plug. Lots of info online on how to replace it, make sure you use the correct type.
Apr 05, 2009 | Garmin GPS III Plus GPS Receiver
Garmin GPS III plus- ROM failed message
Try leaving it on for a few days on cig lighter with unit ON. gps III plus has a rechargeable valadium battery soldered to the board on the inside of the unit to hold memory of your waypoints.You can solder a new one in for about 5 buks-it may need a new one but try charging it first
Jan 27, 2009 | Garmin GPS III Plus GPS Receiver
Garmin V
I think I may have found the solution.
A reply for a post on another site:
I visited the Garmin Corp office to seek help with that problem. If the shut down occurs right after satellite acquisition and the screen may show just a narrow black line going across it, it is likely due to some program changes the sattelite folks did without telling the software programmers. Garmin web site has a free download fix for the problem. Another option is to go into your settings and turn off the WAAS. Hope this helps. Go to the web site, check downloads, find your model gps and there you go. Good luck.
I disabled WAAS and so far so good.
I couldn't find the fix on the Garmin site.
Oct 12, 2008 | Garmin GPS III
Need to replace memor4y battery in garmin hanhheld gps.Please advise how to. regards George the internal battery is dead on my old garmin gps III , can it be replaced ?
Battery can be replace for around $14 (look at eBay and search for "battery ique 3600"
See this video for insrtuctions:
Aug 19, 2008 | Garmin iQue 3600 GPS Receiver
Garmin gps 95xl battery
Aug 12, 2008 | Garmin GPS 12XL GPS Receiver
Garmin GPS III LCD screen problem
I have a GPSII+ that has a screen problem. Several of the x and y coordinates have failed and I think it is due to condensation in the unit due to hot day temps then cold nights. If I open it and dry out the unit for a while... the display will be better but will not return to full display. Some of the X and Y lines don't work.
May 12, 2008 | Garmin GPS III
GPS Logo
1,507 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
