Does it have to be connected to something to pick up fm radio?
    Guru:
  • 2,178 Answers
No, your headphone should serve as an antenna.
Posted on Dec 29, 2010
Electrohome ean 0s700 radio wont play
Check the aerial connection. Some FM radio's will mute the static and only pick up strong signals. If it is an FM AM radio check the AM radio. If that is OK and the connection's are good you might have faulty Tuner circuit, which would need a trained technician to look at.
Dec 10, 2014 | Audio Players & Recorders
Fm works, am does not
Check the antenna connection. A poor connection will often be good enough for FM but make AM reception so bad the the radios auto-gain circuits will mute the output unlike old AMs that would just produce loud static in poor signal conditions.
Apr 17, 2014 | Car Audio & Video
Wont pick up fm
Deploy the antenna, and orient it. Keep the radio away from electric appliances such fridges, and electric machines. Put the radio on a window sill or close to a window. If a building blocks the line of sight between radio and transmitter reception may be affected.
Dec 10, 2013 | Dewalt DC011 AM/FM Radio
Why does my 1991 Jetta only pick-up AM radio? How do I recieve FM as well?
It's most likely the Antenna connection or the FM bands circuit has burned out. The AM Antenna looks like a coil and is actually in the radio in most models, the FM Antenna is the one built into the windshield or sticking up off one of the fenders or somewhere. Check the connections if you have good connections you'll have to replace the Radio.
May 21, 2011 | 1991 Volkswagen Jetta
Where can i plug my ipod in to my jensen 9410 dvd mp3 receiver
here is what you can use take a rca cable to 3.5 mm cable
thumbnail.aspx?q=410222334008&id=874e2170e5197aa72b7e313258a4fed3 buy a fm modulator
item-3992-5-500.jpg then you can wire up the fm modulator to the jensen radio red power and black ground unplug your antenna from radio plug it into fm modulator and then connect antenna of fm modulator into your jensen radio antenna spot . the connect the rca cables to the fm modulator and then other end into the ear phone piece on ipod . follow the instruction that come with fm modulator you will have to tune your radio to a station like 88.9 or which ever you pick from the select ones fm mod gives you to hear you ipod . http://www.tintingbyfredjohnson.com
Dec 28, 2010 | Jensen VM9510 Car DVD Player
Delphi skyfi2 Xm Radio Receiver car connection
Yes, you can buy an FM Direct adapter that will allow you to transmit directly to your car FM tuner, but if you have an older SkyFi2, the Fm transmitter is so strong, you can sit the radio on the floor and tune your car radio to your preset XM channel, like 107.1 FM and it will work great. Go into "Menu" and pick a channel that's not used locally.
Jul 12, 2010 | Delphi SKYFi2 SA10101 XM Radio Receiver
Access fm radio
You need the headphones connected as they act as your radio antenna.
With out them you wont pick up any radio signals.
Mike
Mar 24, 2010 | Sony Ericsson w580i Cellular Phone
No fm radio stations tune in. 1993 Acura Legend/ w Bose radio/cassett. AM works great. verified all antenna connections already.
Not much it can be really. If it is picking up A.M. no problem then it is not a connection problem. It is a fault in the radio itself. F.M. frequency is the easiest to pick up so get the radio checked as it has to be internal.
Aug 04, 2009 | 1993 Acura Legend
No more TV on Sony TV/weather/fm/am walkman srf-m37v.
There's nothing you can do. With the switch to digital broadcasting, the sound isn't on the same frequencies it used to be so this radio can't pick it up. Right now, nobody's offering a digital receiver for the sound. All your radio is good for now is the regular radio and weather broadcasts.
Jun 16, 2009 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
13 people viewed this question
 Grubhead
Grubhead
