Question about Frigidaire Dryers
My dryer motor is running, but sppiner that holds the clothes is not spinning. what can i do?
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
My dryer will spin when empty but not w/ clothes in it.
either the belt is slipping or the motor is bad and can't move a load of clothes.try this put some clothes in it,keep the door open and with one hand hold in the door switch,have someone push the start switch and with your other hand spin the drum to help it out,if it does spin like this most likely you have a bad motor.
Oct 06, 2013 | Maytag Dryers
My dryer will not spin but motor still runs
YOU NEED TO REPLACE THE BELT JUST WRITE DOWN THE MODEL #AND TAKE IT TO THE APPLIANCE PARTS STORE LOWES OR H.D. CAN RECOMMEND ONE CLOSE TO YOUR LOCATION
Jun 05, 2013 | General Electric Dryers
The motore will run, but it is not spinning. The motor smells hot when it is running and not spinning.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt.
Here is a link to the belt.
Jan 06, 2011 | Amana ALE443RAW Gas Dryer
Just moved into a house in Singapore with a Hoover D6786 dryer. It starts up and spins but repeatedly stops spinning after only 5-7 minutes. Clothes will not dry. What's up? Thanks for any help.
This is normally the sign that the electric motor start/run capacitor has gone faulty: the special motor start/run capacitor, usually around 4 to 10 uF / 450v, helps the motor during the stop/start sequences which require higher torques.
Aug 05, 2010 | Hoover Dryers
Clothes retain water after spin cycle
looks you have to check ur belt....needs more tension ....as it will run loose on motor and spin cycle
Apr 19, 2009 | Washing Machines
Asko Dryer won't spin...need to tighten belt
Does the Motor turn... We have had many motors with bad capacitors .. check the white capacitors for cracks or metal coming out of it...the motors will run with out a load on the but put a few clothes in the drum and they will just hummm..
Jul 19, 2008 | Asko T721 Electric Dryer
Dryer Wont Spin
most likely a motor, If machine runs but not turning, either belt broke, if direct drive, motor
May 01, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dryer spins but no hot air comes out
check the fuses.one runs and other heats it.might be a wire burnt off in the back or on the motor
Mar 17, 2008 | Dryers
Maytag PYE2300AYW starts when I hold the button in, but will not stay started.
The motor will need to be replaced. There is a throw-out switch on the motor that keeps it running after you release the start button. These are generally easy to change, with the only hard part being taking the cover off and putting it back on. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=PYE2300ayw&PartCategoryName=&Keywords=motor Any of these motors listed will fit your unit.
Sep 17, 2007 | Maytag PYE2300AY Electric Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
