Question about Eureka 3041BZ Upright Vacuum
Vacume did not come with screws to hold handle to Vacume need the screws handle falls off vacume hits the floor massietracy@yahoo.com Model # 3041 Type - B2 The answer is simple, send the screws please this will fix the problem. Thanks Dr.Tracy Massie Dr.Tracy Massie Harvard;Dr/PHD; Chief Officer of Internal Medicine;Lead Surgeon Dr. Child Disorders; Princeton Dr. / PhD.; Chief Medical Officer; Lead Councilor
2 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: vacume cleaner
Check the hose and see if it has a clog, also the hose at the bottom. The filters may be clogged, make sure they are clean and that air flows thru them, if not then replace them.
Posted on Jan 15, 2008
My dyson has no suction with the floor part but there is suction for the attachments. Help need to clean rugs
There is a hose under the vacume that connects the "floor part" to the main hose this part gets blocked
It is held on with clips no screws
Aug 06, 2014 | Vacuums
ComThe vacume handle is very difficult to get out of the upright position. It use to take just a gentle tap on the front of the vacume to release the handle. Now I have to stomp on the vacume front to get...
Sorry to hear you're having difficulties with your DC14. The cleaner should recline easily into the vacuuming position when one foot is placed on the cleaner head, and the handle is lowered. If it's not doing this, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and provide further assistance. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 15, 2011 | Dyson DC14 All Floors Upright Vacuum...
How do you change the belt
on the bottom of the vacume you should see about 4 screws ( philips ) that hold the plate in place, remove the screws and plate and this will expose the motor shaft,belt and roller ( you should also see the broken belt there two ) -- pop out the roller ( pull straight up ). put new belt onto the motorspindle and then onto the roller, snap roller back into place ( note: on the edges of the roller it is somewhat keyed to only fit into the vacume a certain way ), replace the the plate and screws and you are good to go. also while you are getting dirty -- clean the air filter and examine the hose between the floor roller and the suction hose for dirt build up and debris.
c...
Jan 01, 2011 | Dirt Devil M086700 Vision Bagless Upright...
When I step on the head so that vaccum enguages it stops sucking. You no longer hear air being sucked through the handle as well, the head does not **** down to the floor. When you lock the handle in the...
near the bottom of the vacume where the hose bends down to the floor sweeper, check to make sure there is no blockage. this is the most common problem with vacume suction. you can use a wire coat hanger to help loosen the dirt and debris from the line and it is sometimes easier to clean properly if you remove the bottom plate ( like you would if you were changing the belt ). also while you are getting dirty and having fun, this is a good time to clean the air filter, ( tap it out good or/and use a brush or air compressor to clear and clean ).
c...
Dec 31, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do I change the bag on a dirt devil model 103?
On the open end of the bag that slips onto the vacume, there is a cloth "tab" sticking up from the band. Take hold of this tab and lift up while easily pulling back until you see the band about half way off the vacume. Now, you can take hold of the band and pull the bag the rest of the way off. You will notice that there is a "rib" in the middle of the band on the side that faces the vacume. That rib fits into the groove where the band goes on the vacume. When you install the bag put the band on this groove and work the band on around the housing. You can center the "tab" anywhere, just place it where you can get to it easy. The other parts you need are on the internet, I found them all including that rubber plug called the "attachment port" plug. The p/n for the replacement part is 3-201744-601. The original p/n is 3-501744-601 but you'll be better looking for the replacement part number. Good luck!
Dec 30, 2009 | Dirt Devil Vacuums
When I hit the power switch it turns on, but it will not stay on.
If this were mine I would take the old switch off and put a toggle switch from Home Depot in it. Make sure it's rated for 110 volts and the wattage of your machine or at least 100 watts. It should cost no more than 2-3 dinero or about 1/200th the cost of a new one.
May 04, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Replacing broken handle on filter queen vacume
It is always best to have a cirtified & Authorized Service Tech or Center do the work and only with genuine Filter Queen parts and supplies. Both can be found at 800-344-1840 or in Iowa 888-637-4692
If a Authorized Tech can not come out,
  1. Always unplug unit from electric outlet.
  2. Remove top like you were changing filters, also the crown.
  3. Remove cap under handle.
  4. Remove 3 screws from SN plate then remove plate.
  5. Seperate upper from lower.
  6. lift cardboard piece and Silencing Filter.
  7. Now you can remove the 4 screw that hold the handle.
  8. Repace handle and reverse the above steps.
FQ Master
1-888-637-4692 in Iowa
Your Authorized Filter Queen Service & Supplies
Apr 04, 2009 | Filter Queen Majestic Canister Vacuum
Replacing the belt
remove the two screws from the top of the vacume instead of from the bottom and it will be right inside there.! changeing the vacume belt after that is all very simpl and self expl.
Mar 12, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Rainbow dc4 vacume
Take off the round flat water seal, carefully, you will have to glue it back on, remove those screw to take off the bottom piece.
Jan 03, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Eureka 3041BZ Upright Vacuum Logo
44 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
