Question about Garden
Ariens SnowBlower I recently blew a belt on my Ariens 5.5 hp snowblower Mdl# 932140 I replaced it and it blows snow and when i put it in 1st gear the machine goes into reverse. All my other gears work fine. What have I done wrong or where can I find a picture of how the belts should go on, which would be a great help. Thank you
  • dwva Jan 06, 2011
    Thanks so much for the advice worked perfect. Thank you
    Scholar:
  • 150 Answers
Hi dwva, I think you have the belt on properly seeing the other gears work fine. The difference between 1st and reverse can be as little as 1 half in on the drive wheel. It depends on which side of center is the friction wheel riding. Remove bottom pan with the machine in 2nd or 3rd gear notice which side of center is the friction wheel riding. (the friction wheel is the one with a rubber outer ring). Now put it in 1st, is it on the same side of center? There is an adjustment on that linkage, adjust so in 1st is on the same side of center. Happy New Year, hope that helps.
Posted on Dec 29, 2010
Testimonial: "Thank you for the advice worked perfect"
Why do I have hard time starting my ariens snowblower when cold?
does it have a primer bulb been seeing a lot of the bulbs with cracks
Feb 17, 2015 | Ariens Deluxe 28 Model 921022 St28le 2...
Start my new snowblower auger keeps turning
Belt is a bit too tight. If it's NEW it will probably stretch a bit and be OK
Dec 23, 2014 | Ariens 72023 Snowblower Drive Belt 1/4 X...
Parts not available for Ariens ST724 snowblower?
No you do not..you have the model number and hp should do it ..go in on your computer and just put the name,model number,hp and model in that order .or better yet go in on eBay and put that in and most likely you will find it a a reduced cost..good luck
Nov 10, 2014 | Ariens Snowblower Belt 72098, 8hp 1/2 X 37...
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
10 snowblower
Just a matter of the output shaft. If the height of the engine is slightly different, that can be adjusted by buying different sized belts But the Length and size of the Shaft that the Belt Pulley will be put on is the critical item
Dec 05, 2013 | Garden
Snowblower slower/no blowing force.
Electric motor may have a shorted winding, better would be the belt is slipping...... Sparks tell other wise.....
Feb 10, 2010 | Kitchen Appliances - Others
I have an Ariens 624 series snow blower and every time I use the snowblower the snow spits out of the chute. How do I get the snow to BLOW out of the chute far? I've tried tightening the cord for the...
Looks to me like your second stage is not working. If the auger is turning fine, look and see if the secondary thrower is turning. Probably a shear bold on one or the other is broken. Easy fix, but do not put your hands in there when the machine is running!
Jan 09, 2010 | Garden
Ariens ST 724 impeller does not move under stress?
i have a old ariens ST724 snowblower engine will only run with full choke.
Jan 29, 2009 | Farmall Cub Tractor Radiator
Garden Logo
212 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
