Question about Eljer Home
I have an Eljer toilet that runs constantly. Model # AA 061924 It is a power assisted flush type system, and I am looking for a replacment part for the housing mechanism that sits atop the tanks (or will settle for interior working parts for this mechanism).
    Sergeant:
  • 182 Answers
Sending you a link where you might be able to get some part numbers and break downs. Hope this helps.
http://www.plumbingpartsdepot.com/onepcindex.html
Posted on Dec 29, 2010
Need installation instructions for eljer pf2 energizer power flush
Insufficient information to identify your toilet. Go to this site:
http://www.eljer.com/searchResults.aspx?t=3
If you are able to pick up your toilet model or a simialr model; click on the image; click on the Download Tab.
You will find a Spec Sheet, Installation Instructions and Repair Parts Diagram.
Mar 03, 2011 | Eljer Home
Eljer runs constantly. Replaced the flapper to no avail. I can see the wate flow in on the right side of th bowl looking at the tank. Any suggestions?
The next thing for you to check is the fill valve itself, make sure it is shutting off. shut off the water to the toilet and see if the leak stops after a few minutes. it may also be a leaking gasket on the flush valve gasket. also be sure the flapper area is clean. hope this helps. let me know if you need anything else.
Jan 04, 2011 | Eljer Home
On my eljer toilet, I get continuous running of the water. If I shut valve off and pump the tank, the running stops (but only for a week or so). Suggestions? model 150-403 power flush pf/2
I don't know what you mean by "pumping" the tank. If the toilet runs, then either the fill valve is defective or the seal on the flush valve is defective. First, check to see that when you move the float, the toilet stops running. If it does not, then replace the fill valve. If it does, then inspect/replace the seal on the flush mechanism at the bottom of the tank. If this seal is bad, you can usually see water continuously flowing (slowly) into the bowl. You will see ripples on the surface of the water in the bowl.
Jun 01, 2010 | Eljer Home
Flushing and floatball adjustment problems
sounds as though it needs the thing that lets the water in replaced, now a new one won't resemble your original one (or it might) but don't be alarmed, one fits all, you wouldn't want original replacement, cost to much....get a new one called a "fluidmaster", any hardware store, home depot and the like,....cherio, cracklin joe
Jan 07, 2010 | Eljer Toilet Onepiece Canterbury ...
Always have to hold handle to get it to flush
lift the lid,and look, flush, the rubber valve that opens when lever is is pulled should float, so either its very loose or broken and needs to be replaced.plz rate-bozcro
Sep 10, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Eljer Canterbury one piece remove flush valve
I had the same problem and contacted Eljer and they sent me the above instructions to make a tool to remove the flush valve.
Sep 09, 2009 | Eljer Toilet Onepiece Canterbury ...
All three Murray toilets are slow flushing
Possibly a drainage problem. Flush 2 at a time and if they are slower yet then you have a drainage issue. If not get back to me and I will try to be of futher assistance.
Good Luck
Kurt
Mar 18, 2009 | Eljer Toilet Twopiece Murray 091017000
No water at flush
sound like the water shut-off needs to be replaced.
if you turn on/off the shut-off, the tank get enough water to flush, then you get less water every time you use the toilet. that is the shut-off valve problem.
you may able to to just change the rubber seal.
I have not found change the seal will last as long as a new valve. better off, just change one.
Feb 11, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Home Logo
321 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
