Question about Canon PowerShot S3 IS Digital Camera
THE LENS IS STUCK AND THE CAMERA SAYS TO RESET. WHERE IS THE RESET BUTTON?
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Dec 29, 2010
Dropped my camera and now the lens won't retract back in. When I press on the screen says lens error M425-12 (7f80). Can this be fixed and should I take it to a camera repair shop? Thanks
It could be one of two things, you bend the lens when dropped or the pins in the lens has become loose and are stuck.
You can try:
Taking the battery out for about 5 minutes and putting it back in to reset the camera. Also you can try hold the power button down and the ok or select button to to reset it. Also can hold the power and the menu button to try and force the lens out to dislodge the pins. If not,
The funny the is that I would have you drop it again on a carpet but on the opposite side to see if you can dislodge the pins from being stuck, try and have it land flat on its back from a decent height.
If the lens in bent you will have to bring it to a repair shop to have it fixed but it usually costs as much as a new camera.
Sep 06, 2011 | HP Photosmart M425 Digital Camera
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
When camera turned on it says lens error and then shut down
There is a capacitor dump that you can try.
Remove the batteries, wait 5-10 minutes.
With the batteries out, press and hold the power button for 10 seconds or so.
Put the batteries back in and your camera will start over (re-boot). You will know if it worked if you have to reset the date. But if that lens is really stuck you may be out of luck. The cost to repair it will exceed the cost of a new camera.
My camera was stuck with an open lens and saying ?lens error, restart camera.? I banged it against my hand a few times, the lens retracted and all seems to work as it should now. Thanks for the post!
Dec 18, 2010 | Nikon Coolpix S3000 Digital Camera
Lens trouble
appears to be a repair issue... lens track may be off
Sep 17, 2008 | Olympus FE-280 Digital Camera
Canon ixus 75 digital camera reset?
Hi
There is no camera reset for this model, what you are seeing is a generic stuck lens error message.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from
Darntoothysam com
Sep 14, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Sony cybershot dsc w70 lens stuck-- where is reset button?
not all have a reset button. dont think reset will help you anyway. i think you might have the issue on vid' below.
https://www.youtube.com/watch?v=AkEfnF6zVxc
May 19, 2017 | Cameras
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
LCD showing "remove len cap and press reset button" always
Simple! Read warnings carefully! It said "remove lens cap and press SET button"! So remove the lens cap and then press the SET button (or arrow downward in the four directions button)! You don´t need to RESET anything...
Jan 15, 2007 | Panasonic Lumix DMC-FZ1 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
88 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
