Question about Canon PIXMA iP6700D InkJet Photo Printer
Canon Pixma IP6700D
I've try to to print something in my canon pixma ip6700d and it gave me an error A600. After this she didn't work anymore.
Best Regards
Hugo
  • 4,041 Answers
Hi there
Error A600
Your A600 is a paper path error, usually related to the purge unit. Try checking the purge unit for paper stuck in it.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Almost 90% of the time is related to the purge unit being jammed with something and not being able to move.
Look for paper, paper clips, push pins, screws flower bud pods or the like.
The offending item needs to be removed or the purge unit needs replacement.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow.
The purge unit is a white plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail.
You can try moving it back and forth about 5 times or so and clean the rail with a cleanex and putting a little bit of some light oil on it and then close everything up and try it.
If you found this useful all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
Error message A600 on iP6700D pinter --- removed all cartridges as suggested - no change - turned off and attempted a hard reset - no success - will not print at all -
6A00 says the purge unit is jammed on the right side where the printhead parks.Sometimes you can just push back the squeegee assembly to free it and clean with a wet Q-tip. Other times you can only have the purge unit replaced.
Nov 16, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
How do I reset the left margn on my canon ip6700D printer
Margins are set in printing preferences in the window that pops up after you press print. If prints like the nozzle check are off center you need to clean the encoder strip.
Nov 04, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Error code 6A00 comes up on the Canon Pixma iP6700D. We have moved the carriage manually, it doesn't move when the printer starts. Thank you. Kilian Kuntz
That error code tells you that the purge assembly is stuck. If the carriage is locked on the right you will need a shop to open it up and release it. If it's not a paper scrap or something stopping it, you will need a new purge assembly. Around $30.00 to replace.
May 09, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Error code 5100 on the canon ip6700D printer. stops printing part way through. Have tried all the cleaning options.
5100 says the carriage is not moving properly or there is ink or grease on the encoder. One time I found a camera card inside stopping it, but usually it's just grease on the encoder strip behind the carriage assembly.also if the purge assembly on the right is stuck in the up position you'll get that error.
Jan 31, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Printer problem
Hi
All the best
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Oct 08, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
CANON IP6700D PRINTING
i have a ip6700d.the problem is that im trying to scan but it cant connect to the machine. what's the problem?
Feb 19, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Error msg 6A00
Just fixed mine. :-) I highlighted in yellow a small absorbtion pad that sits under the "home" position for the ink heads. This pad was tilted on its side and prevented mechanisms from moving. Once I put it back in its place, everything appears to be working. You might be able to reach this without taking the cover off, but it is tricky. See http://www.fixyourownprinter.com/forums/inkjet/37440 for some info on care with cover removal.
Jan 23, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Canon PIXMA  iP6700D InkJet Photo Printer Logo
175 people viewed this question
old marine
old marine
