Question about Sony Playstation 3 (PS3) Console
I connected my PS3 with HDMI cables to a tv that needed HDMI cables, but when I connected the PS3 back with standard cables, I couldnt get a picture
  • 29 Answers
Your Playstation is in HDMI output mode. Go to settings and then vidio settings, then try to set the BD/DVD Video Output Format to automatic.
Posted on Dec 29, 2010
Iplugge in my PS3 using an HDMI cable and i get no feedback
ps3's are a pain in the _ss..
you need to connect it through your standard cables as well.. use the component cables that came with the ps3 and connect it to your tv's coloured inputs..
change the tv to that source and then go to the video settings on the ps3, and then choose the hdmi option..
now.. once the option is chosen, you have about 30 secs to change the source on your tv to the hdmi source to see the picture while the timer counts down (making sure both the hdmi and the component cables are connected to the tv at the same time)..
now that you are on your hdmi source on the tv, choose accept (X) on the ps3 menu and you should have your hdmi setup
if you run out of time, no problem, just go back to your component source input and repeat the process faster
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
Only sound comes when i connect HDMI cable to my TV for the ps3
you need to select High definition output on the PS3. Connect it via hdmi and via standard lead switch the tv to standard so you can see the picture then select high definition output. Switch over to hdmi and you should see a picture
Mar 01, 2011 | Video Game Consoles & Games
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    Iam not able to get a picture from my hdmi cable, but can still here sound. tried three different hdmi cables... please can you help...
    1. Your Connections Are Faulty
    Quite often, the cause of the no picture problem is a simple one - loose cords. Make sure that the cords are plugged in tightly, both on the TV side and the PS3 side. This is especially true with the HDMI cable connection on the PS3. Often, it looks tight, but you still might need to wiggle it a bit more to seat it correctly. Along the same lines, make sure that the cords you are using are new and match the connections properly on both the TV and your console.
    2. Wrong Connection Settings
    If you are using the HDMI/DVI cables and you don't get any picture, make sure to check your video ouput settings. If your PS3 thinks you are using standard A/V cords to connect to the set, you'll have issues. The opposite is true too - if you are using the A/V cords and your PS3 thinks otherwise, you'll have the same no picture problem. Make sure you settings match the types of cable connectors you are using.
    3. Wrong Resolution Setting
    This is also an easy mistake to make that can result in no picture showing on your television screen. For example, if you've been using your PS3 with an HDTV and then try to hook it up to a standard definition television set, you'll encounter this issue. The cure is simple; just go into your settings and switch back to standard resolution and then restart your system. The 720p resolution is the default setting and this should work for most standard definition televisions.
    Nov 18, 2010 | Sony Playstation 3 (PS3) Console
    PS3 HDMI No picture nor audio
    1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
    2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
    3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
    Jun 26, 2010 | Sony Playstation 3 (PS3) Console
    PS3 - Sony Reciever HT-SF2300 - Aquas A83 LCD TV
    Make sure you have selected the HDMI output option in the PS3 menu, otherwise you will get no picture or sound, connect you standard cable to your tv first which came with PS3 to do this first.
    Nov 25, 2008 | Sony Playstation 3 (PS3) Console
    PS3 No picture or sound
    When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
    Jun 25, 2008 | Sony Playstation 3 (PS3) Console
    Install ps3 on avr-4306
    PLUG THE STANDARD PS3 CABLE INTO PS3 THEN TO TV GO TO SET MENU FOR PS3 AND SET VIDEO OUT TO HDMI,PICTURE WILL GO OFF SO BE QUICK AND PUT HDMI CABLE INTO PS3 THEN TV,NOW SET AUDIO OUT PUT TO HDMI,THEN CONNECT TO AMP,IF YOU STILL GET NOTHING CHECK AMP SETTINGS IE INPUT SELECTION FOR HDMI.
    HOPE THIS HELPS.
    CABLE GUY.
    Jun 18, 2008 | Denon AVR-4306 Receiver
    PS3 conection cables
    Suggest using HDMI or Component Video if you can. They provide the best picture quality. Should be able to use RCAs if need to.
    Try switching the TV Mode. TV may have multiple modes if you have multiple connections.
    Mar 24, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    51 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
