Question about HP Pavilion A820n (PP165AA) PC Desktop
Fan goes into high gear, won't boot up - HP Pavilion A820n (PP165AA) PC Desktop
    Sergeant:
  • 267 Answers
Are you hearing a beep for a long time? You have not mentioned properly what are the other symptoms too, so I guessed one probability. If my assumption is the real case, then your RAM(s) have been dislocated from its slot(s). Re-assemble your RAM(s) and restart your computer. Please let us know, if this was not the actual case or this solution didn't help you.
Posted on Dec 29, 2010
  • 615 Answers
Solution 1:
1.Disconnect all cables and connectors with in a cabinet except power supply (SMPS)take out RAM and clean it with cloth and Reinstall it on same place.And you can also check with new RAM. If this step not solve your problem,go to next step. 2.Check with New SMPS if it doesnt solve problem, your motherboard may faulty.
I think it helps..let me know
My fan won t stop running at boot. Acer t160.
JIMMY,CHECK ALL ELECTRICAL WIRING.IF IT LOOKS OKEY YOU CAN HAVE A BAD PSU.
Jul 11, 2013 | Acer Computers & Internet
Compaq Presario SR1610NX won't turn off, and won't
The problem could be a hardware problem.
You can try removing the ram to see if it's faulty otherwise I am afraid you are unlucky because could be a motheroard problem so the only solution is to bring your laptop to repair service.
Feb 05, 2013 | Computers & Internet
Temperature for laptop is high
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Oct 24, 2012 | HP Computers & Internet
2004 Chrysler Pacifica Blower won't work
Usally when a blower motor resistor goes bad the fan still runs on high. The resistor lowers the voltage going to the fan to make it run slower. The high setting usually goes straight thru. Resistors are usually easy to get to, under good on the firewall or under dash passenger side. Cost about $24 at parts store. Replace with new if that doesn't work return it.
Aug 29, 2012 | 2004 Chrysler Pacifica
Fan of Dell laptop needs repair automatically
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 05, 2012 | Computers & Internet
Radiator fan relays
You need a book. The fans come on when the pressure switch sends a signal to the BCM to energize the fan relays. If the freon charge is low the ac system won't build up enough high pressure to activate the fans. If the pressure switch is bad the computer won't know the pressure is high enough to need the fans. And so on.
Jun 23, 2012 | 2009 Ford Flex
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
A reason the high temperature cpu mercury
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Jul 11, 2011 | Mercury P4VM800M7 Motherboard
HP Pavilion A820n (PP165AA) PC Desktop Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
