Question about KitchenAid KCMS1555R Microwave Oven
Microwave makes noise when turning only in one direction
    Brigadier General:
  • 8,909 Answers
It sounds like the turntable motor is failing or the turntable requires its wheels cleaning. If it is the motor, it is a synchronus motor with a plastic gearbox reducing the RPM to about 5. The gears fail when the turntable dish is turned as the motor stalls the shafts.
Replacing the motor is no big deal.
There is usually an inspection cover that can be removed on the underside of the cavity.
Remove the cover and remove the motor.
Replace with the same type and the reverse procedure will fix it.
You may however require a self tapping screw to affix the cover back on. A bit of a puzzle but not too difficult to work out!
Hope this helps.
Posted on Dec 29, 2010
The stirring motor was making a grinding noise then the stirring and the turn table quit working, the microwave still runs but will not heat.I can replace the stirring motor where is the fuses
In most microwaves, there is only one fuse, and if it blows, all power will be lost.
To help you further (with free advice), I would need to full model number and FCC ID number from the label on / in your microwave.
Contact me directly here.*
* FixYa doesn't always notify us Experts when you follow up online
Jan 28, 2018 | Microwave Ovens
Microwave won't heat, light ,clock works the microwave just won't heat the items in it.
hELLO THERE
when a microwave quits heating but every thing else is ok normally
investigate these 4 areas
Investigate these three areas if your microwave won't heat but you hear a loud buzzing or humming noise:
microwave_diode.jpg Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
picturena.gif High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
microwave_magnetron.jpg Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Nov 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Loud noise and not heating up
if its making a loud humming noise you need to remove the outer and carefully discharge the high-voltage capacitor in the magnetron circuitry(caps are usually oval in shape and 3 to 5 inches long) after this disconnect one terminal of the cap and check it for being open,then do the same on the high-voltage diode and check this for front to back resistance high in one direction and lower with the meters leads reversed on the diode,the humming is coming from the transformer not being loaded by the cap and diode to double the voltage required by the magnetron tube of -2,000 volts D.C.
Apr 26, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
I have a JES1142 which I purchased only one month ago. The turning plate rotates both clockwise and counter clockwise. When it rotates counterclockwise it makes a grinding sound. Why does it rotate bot...
It's normal for the motor to turn both ways, that's because of how the motor is made. As for the grinding noise, there's no reason the motor itself would make more noise turning one direction than in the other. The noise might be coming from the roller ring under the glass turntable. One of its wheels might be binding when it tries to turn counterclockwise.
Here's a test. Take the glass tray and roller ring out of the oven. Put a microwave-safe container with a cup or so of water in the oven and start it. Stop the oven and start it again, and the motor should turn the other way. If not, repeat this until you've seen the plastic coupling turn both directions. Note whether you still hear the noise as the motor turns each way. If you do, then there is something wrong with the motor and it should be replaced. If not, the noise is coming from the roller.
In either case, if the oven is truly only a month old it's still under warranty. Since you are concerned about the noise and are worried that the oven is defective, contact the store where you purchased it and see if they will exchange it or take it in for service. If the store can't help you, refer to the owner's manual for the service procedure to follow.
Hope this helps. Thanks for using Fixya!
Feb 13, 2010 | GE Microwave Ovens
The turntable makes noise and is jerky as it turns
I believe your turntable is belt driven as opposed to direct drive. Your little belt is nearing the end of its useful life, I think.
Remove the cabinet. Turn the oven on its back. Look at the bottom.
Oct 20, 2009 | GE JVM1850 1000 Watts Microwave Oven
Ge above range microwave, when it is turned on it makes a rattili
is this noise a loud noise or low. and tell me the make and what the model. please
Mar 20, 2009 | Goldstar MV-1501 Microwave Oven
Microwave doesn't heat up
There are three solutions (source) =>
http://www.partselect.com/repair.aspx?appliance=microwave&part=no-heat
Power Diode
Magnetron
Dec 31, 2008 | Microwave Ovens
The turn table goes clockwise sometimes & counter clockwise sometimes.It also makes a groumbling noise.
The motor for the turntable in these ovens is bi-directional. This is normal.
As for the noise, it is very common that the main turntable wheel track-ring under it is dirty at its wheels, or its pin-pushings have some wear. It is also posssible that the main turntable motor has become noisy from use and age.
I have had microwave ovens make a grumbly sound when one of the cooling fans are going defective.
Jerry G.
May 14, 2008 | GE Microwave Ovens
Hotpoint OTR Microwave - Carousel Motor Noise
You should be able to access the turntable motor if you remove the left side filter under the microwave. Disconnect the power, remove the left filter and look up inside that area, the motor may have a cover or plate over it, if so remove it, the motor will be held in with 2 screws (usually) and there will be 2 quick disconnect wires attached to it. If you cannot get to it that way you may have to remove the bottom of the microwave (underneath), should be only 3 to 5 screws holding it in place, the side to the wall will be hinged, once you pull the screws just let it hang or swing down away from you. Then follow the above directions. Make sure that you are getting the correct motor, there are two types, one is a square shaft (WB26X10037) and the other is a "D" shaped shaft (WB26X10038).
Jan 21, 2008 | Hotpoint RVM1635 Microwave Oven
KitchenAid KCMS1555R Microwave Oven Logo
169 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
