Question about Canon PowerShot A470 Digital Camera
I cannot take a picture when there sunlight,it started when i took a picture of burning house is the affected my camera
  • Canon Master
  • 4,738 Answers
No, the burning house unlikely cause the problem. The A470 is particularly subject to something called a "stuck shutter". A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Now recommend proceeding directly to Fix 5A listed in the article. If that doesn't help, your camera may have a more serious problem of a broken ribbon cable to the shutter. This seems to be very common for the A4XX series cameras from Canon. Here's some info on the problem.
Posted on Dec 29, 2010
Exilim underexposed
Making copies of old photographs sometimes requires special lights and equipment such as polarizing filters and specials polarized lights, If you are using available light you automatic exposure system in the camera is probably selecting a slow shutter speed thus resulting in blur. or perhaps overexposure.
Quick method- Take to picture out of doors in hazy sunlight or open shade, hold the camera firmly and try the shot again. If that does not work- tell me what kind of camera you are using and how and where you are shootin.
Ed
Aug 03, 2013 | Cameras
The first time i got my film developed the pictures came out nicely. the second time the film came out off colored, it was more pink then normal. the third time the film came out off colored, the color...
Either the development house you took it to is not reliable, you're shooting out of date film, or in bad light.
Remember that film is designed only to look good in sunlight outside. They sell colored filters you can place on the front of your camera if you need to shoot inside without the colors looking off.
Feb 17, 2011 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Direct sunlight to the back up camera creates a large vertical line and blurrs out on the monitor. Is there any way to correct this? thanks
Look for a crack or partially open seam in the camera housing that could be letting light in from the rear. If the housing is separating, see if it's because of a missing screw or broken tab of some sort that secures the parts of the housing. Place a piece of opaque tape (duct tape, etc.) over the affected area.
REAL men only have (or need) two tools in their tool box: A can of WD-40 and a roll of duct tape. If it moves and shouldn't, use the duct tape; if it doesn't move and should, use the WD-40.
Jan 25, 2011 | Virtual Reality Black Vr3 Wrless Backup...
POSSIBLE MOLD INSIDE CAMERA LENS
It is lens fungus and you're correct in your assumption that it's uneconomical to professionally repair on your lenses. But it need to be pretty bad before it affects image quality so don't junk them just yet.
Some types of lens fungus can be killed simply by leaving the lens out in sunlight, but I'd suggest that it's better to leave them exposed to the indirect sunlight on a bright overcast day to prevent any chance of sharply focussed light burning the inside of the lens. Killing the fungus won't remove the dead stuff but it prevents the problem getting worse.
May 29, 2010 | Quantaray 100-300mm F4.5-6.7 Zoom Lens for...
New Kodak M1033 cannot see image on LCD in sunlight
This is a common problem with all LCD screens without anti-reflective coatings.This is normal. Increase the brightness of LCD while shooting in the sun. Internal memory normally takes only a few images. This is normal. Use a memory card to shoot more images.
Feb 10, 2009 | Kodak EasyShare M1033 Digital Camera
I, took a picture with a bright sun as part of the picture. Now, my LCD just shows colored vertical lines. I, can not take a picture. Is there anyway, I, can fix this problem? Thank you.
Remove your batteries. Let your camera reset. Direct sunlight is never good for your sensor. That should fix it. If it doesnt then you sensor has been damaged unfortunatley repairs on sensor are not cheap
Oct 24, 2008 | Cameras
What is CCD?
A CCD is the Charged Coupling Device. It is the IC chip that scans image from the lens into binary data so that it can be stored onto your memory card. Sometimes they can have different results in light because they are photo senstive and can burn out. That is why it's very important never to shoot pictures in direct sunlight with these unless you have a filter becuase the direct sunlight can burn out the CCD unit.
Jul 04, 2008 | Cameras
Dark Pictures in Auto setting
Do you have a polarizing filter on the lens?
Aug 07, 2007 | Canon EOS-20D Digital Camera
Black Screen
Could be a CCD burn- in which case new camera is very likely
Aug 06, 2007 | Kodak EasyShare C330 Digital Camera
Black Screen/Viewfinder
Mine too! Thank you so much for posting this issue!!
Apr 22, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Canon PowerShot A470 Digital Camera Logo
168 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
