Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Oven is giving an F1 error code - Kenmore 40494 / 40495 / 40499 Electric Single Oven
  • Kenmore Master
  • 1,711 Answers
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Jan 01, 2011
  • Anonymous Jan 01, 2011
    (Clock).
    the ERC
    (Clock).
  • 163 Answers
SOURCE: What does the error code F1 indicate, on a Wolf Oven?
f1 is the control board and touchpad.
Posted on Mar 24, 2009
SOURCE: dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
Posted on Jun 15, 2008
Powerman
  • 68 Answers
SOURCE: Ovens
The F1 error message usually means a short somewhere in the touch panel keyboard. There has been a rash of problems with keyboards. Most of the time there is a simple fix that can be used. Please see my post of April 14, 2007 in response to the problem posted by OVENMAN on April 12, 2007. There you will find a suggested solution which has helped hundreds of folks who have had error messages with GE and Kenmore ovens. If this fix doesn't work, you will need a replacement touch panel. There is no practical way to repair the keyboard in ovens.
Posted on Apr 17, 2007
  • 146 Answers
SOURCE: Jenn Air W131 F1 error code
This means that the Power to element relay energized during time of day display. You have a problem with the wiring harness and it is shorted or you need to change the power relay board (PRB). If it is a double oven, you need to change second oven board.
Posted on Jan 07, 2008
blueextc3221
  • 15935 Answers
SOURCE: Keep getting F1 error code (constant beep) on my GE profile oven.
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
&%YR
Posted on Oct 01, 2010
Trouble code F1 F5
go on google give product name and model # then code errors. it will come up with solution.
Jul 17, 2014 | Kenmore Ovens
When turning oven on there is a beeping sound and error code F1
Most of the answers are correct, the EOC (Electronic Oven Control) is either damaged or shorted. I've also seen the F1 code come up on the version 2 and 3 units when the temperature probe was shorted. But most likely your EOC is damaged and needs to be replaced. Since you didn't give us a model number we can't give you any more info. Good luck
Mar 14, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
F1 code
Most F1 error codes refer to a communication error in the main control board/ clock on some there are reset overload switches that if tripped show as a push button that is pushed outward that you can reset. This also mainly depends on which type of oven that you do have and you would have to provide the make and the model number of the unit in order for me to give you an exact solution to your f1 error instead of a generalized one. Sometimes also you can turn off the power at your electrical breaker for 7 minutes which this causes the control to reset in some. Most of the time in most models though the F1 refers to having to replace the electronic control module (ECM. If you have any further questions or wish for me to look up the exact error for your unit message me back your make and model number and I will give further diagnosis on your unit. Thank you again
Rick
Nov 26, 2011 | Ovens
We have a dacor double oven that is not running and keeps giving us error message of F1.. Neither of the ovens will work.. Any idea what is wrong and how to fix it?
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Dacor Ovens
Kenmore oven giving F1 error code. Oven not working, but stove is working.
The "F1" fault code indicates one of the following possible failures:
  1. Shorted keypad which is part of the Electronic Oven Control (EOC)
  2. Failed Electronic Oven Control (EOC)
  3. Oven temperature sensor is bad (this is located inside the oven cavity at the upper left rear corner). The oven sensor should be disconnected and tested for resistance and compared with the "RTD" scale.
Jan 21, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven is giving a F1 code and is not working . It beeps even when it is not given a program.
Hi.
The error meaning depends on the oven brand.
On Amana and other brands F1 is a faulty control pad or faulty electronic control.
That may be your case , since the electronic control looks being jammed.
Try tripping the circuit breaker for two minutes (or disconnect power cord). If that does not help, then call the manufacturer at the number listed on the owners manual.
Note: on other brands F1 indicates incorrect temperature , and is associated with a faulty temperature sensor. This normally does not cause the electronic control beeping and not responding.
Regards.
Mar 02, 2010 | Ovens
F3 & F1 Errors & oven shuts off
Concerning the F3(Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Concerning the F1(Stuck touch pad)
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Jun 02, 2009 | GE Ovens
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
Jan 07, 2008 | Jenn-Air JJW8230D Electric Double Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
766 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
