Question about Moyer Diebel 24 in. 301HT-70 Built-in Dishwasher
The wash water does not get hot enough. The guage for the rinse shows it is high enough (Approx. 150 F), but the gauge for the wash only gets up to about 100 F.
  • jlkimmet Dec 30, 2010
    Is there a way to check on the functioning of the timer/control board? Is this a repairable item?
  • Moyer Diebel Master
  • 43,501 Answers
After checking for this model dishwasher I am getting nothing....hopefully you know where to get parts for this dishwasher because the timer/control board is bad....
It is not the heating element or it owuld not heat the rinse...so...
It has to be the control not turning on the heat when it is in the wash cycle...
Change out the control and you'll be working again...
heatman101
Posted on Dec 29, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Dec 30, 2010
    No... unless you have a factory bench setup to test the board there is no real good way to test them in the field...
    So of course they are very hard to repair in the field also...
    Unfortunately many times a best guess has to be made and then hope that by golly it fixes the problem....
    I am pretty sure though that your board is bad in this case...
    heatman101
Do washing machine water pumps some how can get that hot from something being already wrong cause the water pump to melt down?
pump running without water will get hot enough to melt plastic .and that would suggest a plugged filter to me
Sep 30, 2015 | Washing Machines
Rinse temp not high enough on hobart c44a dishwasher
If your water temp. gauge (on piping) is showing 180 but the digital display is only reading 125 deg. then I would remove the water temp sensor from the rinse piping on back upper part of machine (It is a small probe with wires coming out of it). Clean probe with emery cloth and put it back in to see if that changes the display. If it doesn't then you may need to replace the probe.
Aug 19, 2014 | Hobart C44a Commercial Dishwasher
Temp.guage on instrament panel is erradic
Could be the temp sensor or the gauge on the dash is faulty.
Does the gauge go to cold if you disconnect the sensor ?
Jan 22, 2014 | Cars & Trucks
Admiral washing machine water not hot enough during all cycles.
newer washers have a temp sensor and the washer is programed for around a 100 to 110 degrees F, depending on manufacturer, so if your washer is new it is doing what it is supposed to do, sorry.
Jan 03, 2012 | Washing Machines
Temp guage read hot, volt guage reads low, and oil pressure guage tops out. Could this be a bad ground?
Possibly, i would check the sending unit and of course the wires that connect to the temp prob. They often become worn or even short out on other wires. I suspect that the gage is telling the truth and you have a blown head gasket. Check the oil for water. Check the water level and see if you are losing water. good luck
Jun 03, 2009 | 1996 Ford Thunderbird LX
No rinsing water coming in
There are 2 versions of this washer dryer, a cold fill only one and a hot and cold fill version.
If it is the cold fill version, it could be the water level switch that is malfunctioning, cutting off before the correct level is reached, or a sticking water inlet valve.
If it is the other version, then the same thing applys, plus the coil on the valve that controls the rinse cycle could be open circuit.
You need a meter to test the valve coils for continuity..
Make sure that there is actually cold water to the valve, if it is a hot and cold fill model.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Indesit W 123 Front Load Washer
Tank temp
check to see if your element is scaled up or your element may be damaged
Nov 21, 2008 | Hobart AM15T Dishwasher
Water temperature is not hot enough
the heater in the unit is supposed to heat both the wash water and the rinse water.
if it is not, then you have a problem in a controller or an element.
how are you determining the temperature and are you waiting for the unit to signal ready before you test it?
mark evans
markevansmarkevans@hotmail.com
Oct 12, 2006 | Jet Tech Systems 24 in. 737 Free-standing...
Dishwashers Logo
51 people viewed this question
Top Moyer Diebel Dishwashers Experts
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
