Question about Whirlpool AWM8123 Front Load Washer
Hi there, I have a Whirlpool AWM8123/3 machine. When in the wash cycle the machine goes into fast spin mode for about 1 second before settling down to its normal routine Washing machine then jumps about as I guess extra water causes load not to be balanced. Seems to be intermittant -is it a timer/programmer problem?. Sometimes get F06 fault code as well but not sure if it is related thanks Paulmac
  • 1462 Answers
SOURCE: Whirlpool washing machine
check that the machine ramps up to spin speed reasonably and distributes the clothes- ie doesn't spring straight up to spin speed. if this is ok then the fault may well be the shock absorbers located at the bottom of the machine and going from base to tub. check also that the counterweights are intact
Posted on May 09, 2007
SOURCE: The duet washing machine fills up with water in between loads. What is Causing This?
Dont want to endorse a commercial site, but you can by a generic part for a bit over $10 for this problem, so do some seraching for a reasonable site (other sites are charging 40-50 dollars for a fill valve.
Posted on Aug 09, 2007
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
huuum
  • 750 Answers
SOURCE: Getting HF error, on Whirlpool Front load washer
Dear jodyheidi,
Welcome to fixya.com
I'm Huuum and happy to assist you,
Try this first and if it fails to remedy the problem then call service as you wanted!
Huuum At your service!
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
let me know how it works out.
How old is the appliance?
Let me know how you progress!
Bless You, Huuum
Please remember to leave a rating when you are finished!
Thank You
Posted on Sep 23, 2008
  • 111 Answers
SOURCE: Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
Posted on May 21, 2009
Is Whirlpool AWT 5108 only a washing machine or a washing machine with dryer?
Washing machine usually have different wash cycles you can chose from. The washing machine should go into a spin mode to get most of the water out of the cloths at the end of the wash cycle. You might try another wash cycle on the washer and see if the washer goes into spin mode and gets most of the water out. If it goes into spin mode on one cycle and not another my experience has been it is the timer which is part of the switch where you chose which wash cycle you want.. My experience is only working on my washers and driers of the last 40 years. I have washed cloths with what ever cycle worked till I could change timer.
Nov 19, 2017 | Whirlpool Washing Machines
My Kenmore when in spin cycle it shakes all over the floor rattling and shaking
I can't offer a definitive answer but I have had a little experience.
It is possible it is spinning too fast. The brain of the machine needs to know how fast the motor is spinning in order to control the speed. The motor is fitted with a tachometer sender for this purpose. It is important any replacement motor is fitted with an identical tachometer to the original.
The brain is programmed to cycle the spin slowly at first at increasing speeds to allow the washload to settle and for most of the water to be removed so when full speed is reached there will be less vibration. Perhaps the cycle is incomplete or absent and it is starting on a high speed spin...
The washtub suspension can become worn and weak even though it appears intact...
It is conceivable the drum is imbalanced - a drum that is nicely balanced will not vibrate when spinning without a washload.
Dec 27, 2017 | Kenmore Washing Machines
Washing wont fast spin and empty
Possible that the control has failed and so does not instruct the main board to control the spin and continue with the drain.
Need to check the voltage on the controller and the drain pump at the cycle to confirm this case.
Jul 25, 2012 | Whirlpool Washing Machines
Trying to locate the belt on a Whirlpool washer
Hi:
Your washer does not have a belt. It has a transmission, and they seem not to fail very often. Usually, the problem lies with the timer or some other switch. What exactly happens when your spin cycle comes around? Normally, after the wash cycle, the machine stops, then the spin cycle starts in the opposite rotation. The first thing that happens is the water is pumped out, then as the speed increases, the spinning throws the rest of the water out of your clothes. If your machine does pump down the water, but doesn't spin fast, then you might have a transmission problem, but if it also fails to pump out the water, you could have a timer or switch problem, as some machines won't spin with the lid open, and if the switch is broken, the machine thinks the lid is open.
Feb 15, 2010 | Whirlpool Washing Machines
No high speed spin cycle
I just had a similar problem. The washer would just shut down prior to the high spin cycle. I had a service guy in and he had a diagnostics sheet. Did you get an error code? If you have the electronic. Turn the knob to the Drain/Spin mode and press both the "Options" and "Cancel" buttons simultaneously until all control panel lights are lit and flashing. Then turn the knob clockwise in click and the washer will then go into its diagnostics mode. With every click it should do something (i.e. fill, pump, drain, spin, etc..) continue turning 1-8 clicks. On the 9th click you should then get an error code. My code was E47, which I have already posted another possible solution. I could be either the door switch or the control panel. Remove the door switch by removing the wire around the rubber seal, then remove the 2 screws for the door switch and unplug the 3 plugs. Check the readings on the PTC (white plug on doorswitch). If the switch reads around 1500 ohms, then the problem is most likely the control panel.
To exit the diagnostics mode, the easiest way is to unplug the washer, wait 10 seconds, and then plug it back in.
The reading on my switch was 1398 ohms, which is close to 1500, so I ordered a new control panel. Hopefully, this will work.
Jan 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
My washing is still very wet at the end of a wash cycle and when I try to put the washer on a short spin cycle nothing happens. the drum is definitely turning through the wash cycle but not turning very...
Could be an issue with the timer. For the typical later model Whirlpool/Kenmore direct drive washer the motor always turns in the same direction while agitage and spin go in opposite directions. There is a transmission/gear box which allows whis to work. The timer is supposed to pause for about 10 seconds just before the spin cycle to allow the motor to stop and then start again when the gears are set to spin mode. A bad timer (which is a common problem) may not be allowing this reset and the washer won't spin all of the time although it may agitate and may spin some of the time.
Tell-tale sign of a bad timer is a small burn mark near one of the connectors. You may have to remove the timer to see this and even then look very closely.
A new replacement Whirlpool timer will run you between $100-150 for the part.
Hope this helps.
bd.
Sep 16, 2008 | Whirlpool Washing Machines
Not spinning in high speed
possibly a faulty "off-balance" detector, but not sure...try to purposely make it go off balance during wash...maybe a few pairs of sneakers?
Jun 02, 2007 | Hoover Nextra HNF 3157 Front Load Washer
Front load Whirlpool Duet
Hi, Has the door catch,which protrudes and goes into the hole, broken off, it should have a sort of hooked end. Tom.
Mar 14, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM8123 Front Load Washer Logo
35 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
