Question about AT&T 964 Corded Phone
Desk phone says low battery --where is the battery
How do I turn the ringer off on my samsung iDCS18D at my desk.
HAVE YOU PHYSICALLY PICKED UP THE PHONE AND LOOK ON THE BOTTOM ?? MOST HAVE A LOW, MEDIUM OR OFF SWITCH FOR THE RINGER ON THE BOTTOM OF THE UNIT.
Jan 06, 2015 | Samsung Falcon iDCS 18D Display Phone with...
How do you change the battery?
you need to change the battery in your main control panel, the keypad does not have a battery installed. somewhere you should have a white metal box installed, open the box and you will see a black battery. remove it and take it with as a sample. be sure to check your power supply as low battery normally means that the battery is not recieving power to charge. take a multimeter and test the voltage before changing the battery.
Oct 02, 2013 | DSC WT5500DMK Desk Mount and Power Supply...
What kinds of reception desks are available?
Differentkinds of reception desks include straight reception desk, l-shaped receptiondesk, and curved reception desk. For more information, check out the followingwebsite: http://www.business.com/guides/reception-desks-types-and-styles-30567/
Jul 25, 2012 | Furniture
My phone fell into water.since then,the screen has bn malfunctioning
if you know how to diassemble it clean it inside because you have a problem with connector, or bring it to the qualified cellphone technician and have it clean there
Feb 04, 2011 | Nokia 5800 XpressMusic Smartphone
I have an older phone Bellsouth model 8801 wall/desk mount--the caller idea is not working in the handset--is there a battery component to fix it? Thanks
If it's the cordless version, the called ID is supposed to work off the power cell that came with the phone. If it's the corded version, there should be an access door under the base unit (wall/desk mount).
Oct 09, 2009 | BellSouth Lands Phones
Battery dies quickly
your battery could be defective I would return it and get a new one
Aug 30, 2009 | Motorola Mobility Moto Q
Battery will not charge
looks like the solution is pay a bloody fortune to lg to check if they can fix it or do what im doing and buying a desk top charger i have all ready bought a second battery so that way one can be in the phone while the other one is charging .they only cost about 10 dollars ill let you know how that goes
May 06, 2009 | LG KC910 Renoir Cell Phone
Digimax 401 keeps saying batteries low
the camera tends to take up a lot of battery so what the best solution is to buy some rechargeable batteries those work great. i have some of those. and they tend to last a very long time!
Mar 02, 2009 | Samsung Digimax 4010 Digital Camera
Battery charger
Sounds like a bad battery. If so, be sure to recycle it. You can carry them to Lowes or Home Depot and drop in the recycle bin, usually by the front returns desk.
Jan 26, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
AT&T 964 Corded Phone Logo
67 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
