I bought a used kp 61hs30 sony projection tv. It is too tall to fit down the stairs into the basement. I heard the top part with the screen justs lifts off the base - where the components are (after you undo the screws). Is this a viable option for me or will I screw up the projection alignment. Are there wire harnesses that need to be undone?
    Brigadier General:
  • 8,909 Answers
The top as you describe it, can be removed for cleaning and moving. There are no electronics there and allignment will not be affected.
Hope this helps.
Posted on Dec 29, 2010
Is the sony KP-61hs30 a HD television?
Hi, Although it is a rear projection TV it will work with HD content.
You will still need a set top box to decode HD programs. This is an old TV with tubes inside and a CRT screen. They will fail and it's getting harder to get parts for. My advice go get a flat pannel TV.
Good luck
Feb 04, 2016 | Sony KP-61HS30 TV
I have a kp-61hs3o rear projection HDTV. It is too tall to fit in the basement. Somebody told me I can lift the top half with the screen off the base (where componets are) by just undoing the screws. Is...
You can lift the top section away from the electronics. There are quite a few screws!
It will not affect the allignment and makes it easier to move and clean the mirror.
Dec 29, 2010 | Sony Televison & Video
My Sony kp-61hs30 has no power. no blinking
Check fuses on power/delection board. Besides normal looking fuses there are micro fuses that are small and are yellow or blue in colour
Jan 07, 2010 | Sony KP-61HS30 TV
Will not power on, red light flashing six times
the problem is in the power supply most likely. The overvoltage protect circuit is causing you not to be able to turn the tv on. This is common to all tv's. Solution unfortuantely is get another tv unless you know someone who can either work on or replace the internal power supply
Jul 01, 2009 | Sony KP-61HS30 TV
Moved, now can't get the TV downstairs
it went down the stairs in one piece it should come up the same way
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
KP-61HS30 Sony TV turn pink and green text is bowed
Check out CONVERGENCE GALLERY . If you see your symptoms you have a problem in your convergence amplifier circuits. Typical Sony Convergence repair requires disassembly for replacement of 2 ICs, sometimes a fuse or 2, then TV is like new.
It is much more complicated than changing batteries on your remote. Many consumers try unsuccessfully to do a convergence repair. I recommend finding someone competent to do it for a reasonable price. Typical repair shop charges may be from $400 to $650.
If you are in the Calgary area, call me. More reasonable rates.
easyab
Jul 31, 2008 | Sony KP-41T65 41" Rear Projection...
Sony KP-53XBR200
check cable grounding, does it do it with a dvd?
Feb 01, 2008 | Televison & Video
Black screen
my sony kp-61hs30 displays that there is no siginal, also the red indicator light blinks when the power is turned on but goes out i have dirct cable pluged into the set and up until about a week ago it worked fine.All of the other tv's in my home work fine so i don't understand what the problem is . I have a dvd player connected to the set and it works great for viewing dvd's please assist with me with some trouble shooting points
Jan 24, 2008 | Sony KP-61HS30 TV
SONY KP-61HS30
When one or all the colors are bending severly, then the convergence circuit is not functioning correctly and must be repaired. Only one color bending means just the convergence ICs and all colors bending means convergence ICs and voltage supplies. Convergence issues are the most common problem with rear projection (w/picture tubes) televisions. The cure is replacing the convergence IC's. Sometimes the pico fuses need replaced as well. If you have the experience to use a soldering iron and a basic understanding of electronics, then, you may be able to do this job. If not then call a servicer in your area. Go to the Sony website, Sony.com, and you can locate one in your area.
Jan 07, 2007 | Sony KP-61HS30 TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
