Question about LG Neon GT365 Cell Phone
Communication error (20) - LG Neon GT365 Cell Phone
What is communication error 20 mean ?
The Comm. Error message may appear if the machine experienced a communication error while sending or receiving a message. This type of error is generally caused by interference on the telephone line, an incorrect telephone line connection, or an alarm system or other device on the line. In your case, it lost connection to the host / server. You just need to keep retrying or check the settings on the phone and confirm with the vendor if they have changed some settings on their end...such as PORT #, etc...
Sep 02, 2015 | Computers & Internet
Error 20 01
Error 20 01 indicates that there is a communication error on the telephone line connected to your MFC. Either the line is noisy, not connected or perhaps connected via a PABX or a VOIP modem or similar? so it will not work. Try plugging a standard telephone into the socket and see if that works. At the very least you may well be able to "hear" the fault. At the very least, the fault is external to your MFC and not within the machine itself
Nov 06, 2013 | Brother MFC-8910DW Laser Multifunction...
Lg wm1815cs error code le
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
Dec 10, 2012 | Washing Machines
Communication error !! check all conections and make sure all device blablabla.....
check your communication cable. usb cable or parallel port. Replace the cable and try again.
If still not working then may be the main board has got problem.
Mar 11, 2011 | Epson PLQ-20 Matrix Printer
Communication Error 20 02
Contact Brother Error 2002 is a fault basically saying the printer is knackered
Dec 30, 2009 | Brother MFC-7820N All-In-One Laser Printer
Communication error 20
i think you have to install the opera mini browser in your device. i hope u will get the solution.
Oct 06, 2009 | Samsung SGH-A877 Impression Cell Phone
Communication Error
Stop using the USB port and buy a memory card and card reader. 20-30 dollars and problem solved.
Jul 01, 2009 | Fuji FinePix Z100fd Digital Camera
Error 20
Sometimes i can get it to retrieve on another station. Maybe its a communication issue and taking too long to retrieve so it timed out.
also you can change the program to wait longer before timing out.
Jun 12, 2008 | Compsee Apex II
OKI 5550mfp Fax Problems
error 209 - Media Table Download Failure MediaTable Download to PU failed. Reboot.
CU firmware detected an anomaly in behavior in PU (including a violation of communication protocol between CU and PU).
are you suing unusual sized paper?
Feb 19, 2008 | OKI C5550N Multifunction Printer - Color...
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
LG Neon GT365  Cell Phone Logo
41 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
