Question about Bosch SHU9915UC Dishwasher
The above chain exactly describes our dishwasher. I went ahead and got a new brain for it but how do you get the top housing/cover off to access the circuit board?
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
I can provide you with the complete service manual, it's up to you. You'd need to provide an email address though for me to send the service manual to.
I think the service manual can lay out for you in more detail the procedure to install a new control than I can. I'll watch for your reply.
Regards,
Macmarkus :)
Posted on Jan 03, 2011
  • Mark MacDonald
    Mark MacDonald Jan 03, 2011
    Hi Greg,
    I just sent it, you should receive it soon...if you haven't already.
    Regards,
    Macmarkus :)
I have oil leaking from either the timing chain or the front main
if the front seal leak you can just replace the seal, if the timing cover is leaking then you will have to remove the cover. while you are in there, I suggest that you go ahead to replace the timing chain ( timing set ), seal and a new cover. parts cost less than 100 dollars.
May 25, 2010 | 2000 Chevrolet Blazer
How do I access headlight bulbs on a 2009 Dodge Ram 1500?
I hope describes correctly the detail procedures for replacing 2009 Dodge RAM 1500 Headlight Bulb.
- First, open the hood; Disconnect the negative battery cable;
- Remove the four grille attachment bolts;
- Remove the grille;
- Remove the two headlamp assembly attachment bolts;
- Then reach into the front wheel house ahead of the front wheel to unsnap and lift the cover over the access hole in the front of the wheel house splash shield.
- Access to the bulb retainer can be gained through the wheel liner hole (see picture).
After that reach through the access hole to access the rear lamp retainer and remove headlamp assembly (see below picture).
Disconnect electrical connectors, and replace the bulbs.
Good luck (remember rated this help).
Nov 26, 2009 | 2007 Dodge Ram Truck
Power off
Howdy. I suspect a power surge went through your machine and fried its itsy bitsy brain.Its time for a new one unless you have a good supplier and serviceman who will replace the control unit. Get an estimate with a closed top cost before you agree.
Sep 16, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
It seems to turn on but no water flows in I can here the motor running but no water flows the water has not been shut off
There are two possible reasons for the situation as you describe it: 1. Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
2. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
If you are mechanically inclined you can repair either of these but if you are not you will have to hire it done. Now that you know it is one of two problems you can tell the repairman ahead of time and get a price on the repair. Then shop around for the best price.
May 08, 2009 | Dishwashers
Only wants to fill
May 08, 2009 | Hobart 42 in. AM14C-154 Free-standing...
Skips 1st water fill ?
May 08, 2009 | Maytag Dishwasher
No water coming in to dishwasher but everything sounds like its running
May 08, 2009 | Beko 24 in. D3421F Free-standing...
Soap doesn't dissolve no matter how many times dishwasher is on.i tried different soaps,we have a new sink and new disposal,but still nothing!
It doesn't sound like the water is entering the dishwasher.
Oil pump replacement
This MAY seem Strange But It IS ALL necessary for Oil Pump Replacement. And Please Don't Forget to Rate Me as Most Folks Do Not. Thank You and GOOD LUCK with the Oil Pump Job Also
OIL PUMP
It is necessary to remove the oil pan, oil pickup and chain case cover to service the oil pump rotors. The oil pump pressure relief valve can be serviced by removing the oil pan and oil pickup tube. Refer to Timing Chain Cover Removal and Installation for procedures.
DISASSEMBLY
  1. To remove the relief valve, proceed as follows:
  2. Drill a 3.175 mm (1/8 inch) hole into the relief valve retainer cap and insert a self-threading sheet metal screw into cap.
  1. Clamp screw into a vise and while supporting chain case cover, remove cap by tapping chain case cover using a soft hammer. Discard retainer cap and remove spring and relief valve.
  2. Remove oil pump cover screws, and lift off cover.
  3. Remove pump rotors.
  1. Wash all parts in a suitable solvent and inspect carefully for damage or wear.
Oil Pump Assembly
  1. Assemble pump, using new parts as required. Install the inner rotor with chamfer facing the cast iron oil pump cover.
  2. Tighten cover screws to 12 Nm (105 inch lbs.).
  3. Prime oil pump before installation by filling rotor cavity with engine oil.
  4. Install chain case cover. Refer to Timing Chain Cover Installation.
REMOVAL of Timing cover
REMOVAL
  1. Disconnect negative cable from battery.
  2. Remove timing chain cover.
REMOVAL Of Oil Pan to gain Access to OIL PUMP
  1. Disconnect negative cable from battery and remove engine oil dipstick.
  2. Raise vehicle on hoist and drain engine oil.
  3. Remove bending brace to transaxle attaching bolt.
  4. Remove bolts attaching dust cover to transaxle housing. Lower dust cover to gain access to oil pan bolts.
  5. Remove oil pan screws and remove oil pan.
INSTALLATION
  1. Clean surfaces and apply a 1/8 inch bead of Mopar (R) Silicone Rubber Adhesive Sealant or equivalent, at the parting line of the chain case cover and the rear seal retainer.
    1. Use a new pan gasket.
    2. Install pan and tighten screws to 12 Nm (105 inch lbs.).
    3. Install dust shield and bending brace to transaxle housing.
    4. Lower vehicle and install oil dipstick.
    5. Connect negative cable to battery.
    6. Fill crankcase with oil to proper level.
Mar 27, 2009 | 1998 Chrysler Town & Country
Water Pump
first you have to take off the exhaust manifold. then take off the top motor mount and lift plate on the passenger side on top. then take off the 25 little bolts and nuts off the timing chain cover. with the cover off, take out the bolts on the timing chain tensioner (towards botton, by the crank, looks like a little rod in a aluminum housing). now take off the curved tensioner shoe and the chain will loosen. take the chain off. now the fun part is getting the bolts off the back of the water pump to the block. then the bolts connecting the water pump to the steel housing. and finally the three nuts connecting the pump to the chain housing. not hard just frustrating. replace the pump and new gaskets (comes with pump) and bolt back everthing back together. you may want to change your thermostat while your there since its right by the pump. now putting the timing chain back on and having it in time isnt the hardest thing but if your a first timer take your time. go to a mechanic and ask to print out intalation insructions on timing chain installation. then bolt it all back together.
Dec 23, 2008 | 1998 Pontiac Grand Am
Bosch SHU9915UC Dishwasher Logo
64 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
