Question about Electrolux EW1000i Front Load Washer
My electrolux EWF 1074 wahsing machine is displayin a symbol that looks like a padlock, not he door lock (key symbol) and though it lets me open the door, and it turns on, it does not allow me to set any washing program so I can't use it! have called Electrolux and they cannot send a technician until Jan 7th! does anyone know what the symbol means? it is not shown on the manual. Tahnk you, Monica (Australia)
  • yadayada
    yadayada Dec 29, 2010
    What is the machine doing? What are the symptoms or loss of functions? i.e. Won't wash? Door won't unlock? Also have you tried pulling the plug from the wall for 5 minutes to try and reset the system
    President:
  • 1,138 Answers
Hi!
Posted on Dec 29, 2010
  • Menandro de Leon
    Menandro de Leon Dec 29, 2010
    In order to remove the lock on your washing machine and make it work again
    just hold the option and extra rinse buttons simultaneously for 6
    seconds...
    you will see the padlock symbol go and then use your machine
    as usual
    That will fix it!
    Mace
How to do with E40 code of Electrolux EWF 1074?
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Aug 24, 2015 | Electrolux Washing Machines
How do I replace the door handle on a electrolux front loader ewf 1074 washing machine
hi
you need to take the door apart to be able to replace the handle
is a easy job but remember the order you take it apart to be able to put it back on
Apr 23, 2015 | Electrolux Washing Machines
Door locked
Try turning the main power off at the socket for 5 mins - the door may open then , if not turn the power back on and see what happens.
i had this problem on an Electrolux and it worked.
Jan 22, 2014 | Washing Machines
Heating element
Remove back plate and you should see it middle bottom of machine ,it has two Spade Terminals with two wire fitted to it also an Earth onto its case,You can look up heating elements on the net, this will give you some idea of what they look like and cost.
Jan 15, 2014 | Electrolux Washing Machines
Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Aug 08, 2009 | Electrolux EW1000i Front Load Washer
I have a ectrolux ewf 1074 with the padlock symbol
you need to turn machine on and hold the option and extra rinse buttons simultaneously for 6 seconds, the symbol will go and you'll be able to use your machine again as usual
Aug 02, 2009 | Electrolux EW1000i Front Load Washer
Unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
May 31, 2009 | Electrolux EW1000i Front Load Washer
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot...
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Mar 30, 2009 | Electrolux EW1000i Front Load Washer
Electrolux EW1000i Front Load Washer Logo
286 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
