Question about Lefroy Brooks Home
Lefroy Brooks Exposed Shower GD 8701 How do i remove the Cross Head Handle to allow the Body to separate. Fault; Coroded Inner, Too stiff to turn !
  • 2712 Answers
SOURCE: How to Remove Shower Head
Once you've purchased your new shower head the first step in replacing the head is to make sure your shower faucets are firmly turned off and then remove the old shower head. If you look at the existing shower head, you'll notice flat spots on what's called a pipe nipple at the base of the shower head where the head screws into the goose-neck pipe that sticks out of the wall. * Take an adjustable wrench and tighten the wrench onto the base of the shower head flat spots. * Turning counter-clockwise, loosen and remove the old shower head. * Clean the threads on the goose-neck of any debris such as old pipe compound or Teflon tape.
Posted on Aug 27, 2008
lester482529
  • 226 Answers
SOURCE: water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Posted on Jun 14, 2009
  • 54 Answers
SOURCE: a single handle delta shower control lets water
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Posted on Sep 26, 2009
  • 50 Answers
SOURCE: The shower head is leaking. I disassembled the
You need to pull and replace the cartridge on your shower valve most likely. It varies by Make and Model, but generally, remove the handle, remove any sleeve around the center spine, remove the round trim plate, close the service stops, remove the retaining clip or ring, and pull the cartridge straight out of the valve body by pulling on the spline... or get a cartridge puller. Then take your cartridge to the store and get a new one. Flush the valve body by slightly opening both service stops and then install the new cartridge and reverse the process.
Generally this problem occurs when sediment has torn part of the sealing o ring on the cartridge. If you send me the make/model and/or a picture I will give you the specific instructions
Posted on Oct 11, 2009
  • 4340 Answers
SOURCE: leaking shower/tub faucet, looking for replacement
Call Moen directly. They will ship what you need to your door, for free.
Posted on Sep 18, 2010
Lefroy Brooks flush valve
Most flush valves are universal, but try to contact manufacturer and see if they can help, or try plumbing supply store (not a home depot)
Jun 21, 2013 | Lefroy Brooks Plumbing
We have a pressure balance tub and shower faucet (D510055BN) that has become stiff and jerky to open. How can I loosen it to make it easier to open and turn on the shower or tub?
you have to turn off water ....remove cartridge and use heat proof plumbers grease on all inner and outer parts of value and cartridge and body...do not be shy with grease...this should make it better than new...if not buy a new cartridge then grease all...try first to see if works..
Feb 22, 2011 | Danze Sheridan Tub & Shower Faucet
Cannot get the hot water handle off. Have remove the collar and the base, handle will still not come off
im not 100%sure on the particular set of taps you have ,but by looking at the picture on screen ill hazard a quess.by the way im a plumber .under the lever for hot water tap is a cone shaped shrowd .narrowest at its point where its in contact with lever and broadest at bath top end .this shroud will screw off .in the middle of the lever you pop off insert and unscrew cross head screw and then back off shroud ,the tap spindle should then be exposed
Jan 19, 2011 | Grohe 25.506.EN0 Geneva Roman Tub Filler...
Need instructions for changing head on oral b brush. cross action power
you simply remove your old head brush, put a little ring (usually rings come separately and are different colors) an your new one and put it on the handle - it will hold.
Dec 29, 2010 | Oral B 2 Replacement Toothbrush Heads...
I believe I have a delta monitor shower faucet. I am wondering why the hot water pressure is less than the cold water pressure. Also I am wondering what size hex head I need to remove the lever so I can...
i dont know the exact size just get the little set that has a bunch connected when you take handle off make sure water is shut down to pipes then take the inner part out of the center there should be two black screens in the ports where water comes in clean those and should be good to shower
May 08, 2010 | Delta & Single Handle Shower Faucet
I believe I have a delta monitor shower faucet. I am wondering why the hot water pressure is less than the cold water pressure. Also, I am wondering what size hex head I need to remove the lever so I can...
It takes a 1/8" allen wrench to remove handle. To increase hot water flow remove plastic dial that sets temperature. It is right behind handle and slides off stem for easy adjustment.
Remove indicator and replace about 1/8 to 1/4 turn counter clock wise to increase to hotter temperature.
Apr 26, 2010 | Delta & Single Handle Shower Faucet
Oct 11, 2009 | Delta & Single Handle Shower Faucet
Water will not turn off
are the handle extensions on the cartridges all the way. i know sometimes the moens are a pain after you put the trim on to get them on and seated right so it actually spins the cartridge. also check the cartridge alignment the cartridges have little white tabs on the sides that correspond with a slot in the valve body if they aren't aligned it won't shut off either
Jul 31, 2009 | Moen 2919 Chateau Two Handle Tub and...
Home Logo
Top Lefroy Brooks Home Experts
Donni Steen
Tom Chichester
Are you a Lefroy Brooks Home Expert? Answer questions, earn points and help others
