Show how to setup a computer system - Computers & Internet
    Guru:
  • 2,178 Answers
Why does my computer on bootup ask for system password then locks up too many attempts?
If you mean Bios password try this:
Resetting the BIOS PSSWRD, Open the computer case and look inside on the motherboard. Dell has diagrams of this. Locate the Little Jumper. It should have small print if you can read on the mother board indicating PSSWRD CLR. Boot the computer to Setup. Carefully remove jumper, becareful of static, and then once removed hit enter. Shutdown the computer, and restart and enter Setup again F2. The password should be CLR. Turn OFF and PUT Jumper back into place and Turn Back ON. You should be able to access Setup.
If you then boot to setup-check your hard drives and floppy that are seen. You may solve those issues in setup.
If you mean the windows password: boot to F8 safe mode and log
on to the ADMINISTRATOR not your log in that has admin rights.
Disable all passwords and restart.
Aug 16, 2014 | Dell Dimension 4600 PC Desktop
Auto does not show in system
On Honeywell thermostats you have to program the thermostat on the setup mode to have the auto to be on the display. The setup instructions will walk up through it. If you do not have them, you can down load them to you computer.
Jul 20, 2014 | Honeywell TH9421C1004 VisionPRO IAQ Total...
How to restore my compaq nc8000 to factory settings
Hi, When your system restarts displays message to enter in setup mode. Whatever it shows KEY to enter like F10 or F12 to enter setup, press the key and enter into setup then select Restore Factory Setting by selecting the option from the list.
Thanks,
Regards
Apr 05, 2013 | Computers & Internet
Lap top will not boot need to know how to set the boot options in the bios
If you are interested in doing it more easily and quickly. I think you can try this computer boot up suite. When your computer crashes, cannot enter Windows, or you want to work under boot environment, this is your NO. 1 choice.
Jun 06, 2011 | ASUS Computers & Internet
Mycomputer is locked and will not open. Monitor showes: Please enter Setup to recover BIOS setting. PressF1 to run setup. Press F2 to load default values and continue. Nothing works...it is locked up....
If both F1 and F2 are not working and your computer is locked up, there is nothing else you can do other than restarting your computer. There may be deeper issues with it if it managed to show that screen in the first place. To restart your computer, hold the power button down, and when it turns back on plug it back in. If that does not work, you may have to resort to unplugging it.
May 29, 2011 | Computers & Internet
So I have a new HP OFFICEJET 6500 model 709n printer that returns an error at 94% or 96% every single time during install. Ive tried everything It usually gets stuck at step 4 of 4 at configuring your...
Make sure that
(1) Your Computer is free of Viruses otherwise get a good anti virus update it and check and clean your computer.
(2) Take a good Registry cleaning software like RegCure, Registry booster etc and use it to clean the registry of your computer with bad links and other corrupt information of your Operating System.
These registry software are very basic and easy to use and I recommend it to be a must of all client PCs.
If you have problems in buying one try this freeware Registry cleaner.
http://www.wisecleaner.com/
(3)If this does not help then change your printer setup file it must be corrupt. You should attain a setup file for your printer from a different source or try your setup file which is giving an error, take it and try to install it on another computer if there is a similar error than the problem is definitely with the setup file.
On the contrary time if there is no error and setup installs smoothly on the other computer then your computer especially the Operating system(Like Windows XP, Vista and 7) require special attention your PC should be free of Viruses your Registry should be extremely neat and clean and you should be using good Registry software. There will many errors in your registry needed to be fixed by registry software but if your registry does not have the problem which the registry software will tell you.
In the most extreme cases upgrading or reinstalling your Operating System will dramatically show good results provided the setup file is not corrupt.
Good Luck!
Sep 18, 2010 | Computers & Internet
How to instal ms07 from pen drive
Hi Friend,
This is so easy,insurt the pen drive in your system and open the pen drive when you insurt the pen drive in your system at that time one extra removable drive will be show in your my computer,you open this drive and copy ms07 folder and paste into your system,
After that you run the setup.exe file,after few min serial key message box showing your screen (again open the ms07 folder,one notepad file under this,copy the setial key) paste into open setup setial or product key window,and follow thw given instructions,
After the complite instollation go to start button and program option than you find the microsoft office2007
Thanks,
Thanks,
Mar 10, 2010 | Computers & Internet
Bios setup cannot detected 500gb sata Maxtor
hy on your maxtor hdd you have a jumper configuration you have to put your jumper in the good configuration so your primaries hdd is the one that have the exploitation system and the other one you need to set it to secondary hdd
bye and good lock
Mar 06, 2009 | Maxtor Hard Drive
Add password
when the computer is starting up, you can enter the BIOS setup by pressing either:
esc, delete, F2 or F10.
or try to look good when it start up witch is the right one for your system.
In the setup, there is a security setup, and the first one down is the boot up password.
set it and remember F10 to accept the change.
/Teis
Was this solution helpful? Show your Appreciation by rating it:
Nov 30, 2008 | Computers & Internet
Acer 3614 IDE Problem
If the hard drive works in another computer then its more than likely a mother board issue.
Jul 04, 2008 | Acer Aspire 3610 Notebook
Computers & Internet Logo
David Payne
David Payne
