Hi i am just after buying a bush E01LED22USBFHD tv and i ran a digital cable from the sky dish to the television to get the free view channels as there is already a freeview built into the tv so it all worked fine and it found the channels and just after it found them it said save successful and then i expected to be able to watch the tv but all that came up is "video type not supported". Do you know how to solve this i would really appreciate any help?
Nova_1
  • 196 Answers
SOURCE: sky
You do not say which breed of sky you have.. old analogue, digital, sky + or sky HD if you have old analogue then you may have to connect through aerial connection, digital will have a scart socket to connect to your tv, sky + will have the same and finally the cream of the crop sky HD will have hdmi in addition to scarts.
The very least you need to do for a digital picture (not to be confused with hi-def which it isn't) is connect through scart lead then unless it auto-switches to scart input upon switching on sky use your tv remote to select the ext input 1, 2 or 3 etc (some remotes have a button called source for this some call it input etc) select each ext input until you find the one your sky is connected to
Posted on Oct 12, 2008
  • 38 Answers
SOURCE: Windows media center file issue
Some premium channels have DRM locks so that they aren't able to be copied or played on other players, which is most likely what's happening here.
Posted on Jan 31, 2009
GadgetKing
  • 40 Answers
SOURCE: hya im thinking of buying athe panasonic dvd
You can download the manual here: http://service.us.panasonic.com/opermanpdf/dmre85h.pdf
Posted on Feb 28, 2011
  • 212 Answers
SOURCE: Hi I have a problem with
OK...I would try uninstalling and reinstalling again...but I would add a few steps....
FIRST I would BACK UP your data.....there are steps here that can hurt your machine if you are not careful.
try this....run the MS Office uninstall from the control panel again. (for XP use Add/Remove Programs applet...if Windows Vista/7 use the Programs and Features applet)
AFTER you run the uninstall perform these 3 steps (now..this is assuming you dont save your files to these folders!...make sure you have copies of your files!)
1. Browse to C:\Program Files and see if you still see a "Microsoft Office" folder...If so rename it to something like "oldofficefolder" or something
2. XP: browse to c:\documents and settings\\Application Data\Microsoft
Find the "Office" folder and rename it or delete it......I say rename just in case you need to browse the folder again for some files...these locations usually save your settings and configurations
Also do the same in c:\documents and settings\\LOCAL SETTINGS\Application Data\Microsoft (If you dont see Local settings you will have to go to your folder options and show hidden files and folders)
Windows Vista/7 use the same steps except the path will be different. for Vista/7 the paths will be:
C:\Users\\AppData\Roaming\Microsoft
and
C:\Users\\AppData\Local\Microsoft
Again, I would recommend RENAMING the folders in case you find out you need to go back and get the files.
Step 3. (You need Administrative rights on your machine to do this step )
Click start (if XP choose RUN...if Vista/7 Just type in the search field) type REGEDIT
Run Regedit.exe as administrator (WARNING: Be careful editing Registry, it can screw things up on your machine.)
in Regedit brows to HKEY_CURRENT_USER/Software/MICROSOFT find the "OFFICE" key and rename it (again, you can delete it...but I recommend renaming in case you need to undo this)
also browse to HKEY_LOCAL_MACHINE/Software/Microsoft/ Find the office Key and Rename it as well.
After you have performed these steps, there should not be any traces of an old installation for Windows to recognize when it tries to reinstall.....it should think it is installing a fresh copy of office.
Re run the installation from your disk and see if that helps.
Posted on Mar 29, 2011
  • 65 Answers
SOURCE: When I am trying to
-Run regedit (Start menu, run, etc.) and go to this key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Word\Addins
-Export all the addins to a reg file (for backup)
-Then delete all of them in the registry (or one at a time if you want to
know which addin is causing the problem,
-Now try opening a .docx or .doc file in windows explorer and find that
document loads properly with out any error messages!
-now exit MS Word and open the reg file(s) you exported and import them back
-try opening a .docx file again and the problem is fixed. hope this works for you
Posted on May 05, 2011
Hi my Son has upgraded his old tv in bedroom to a Bush smart tv model no DLED32287HDCNTDFVP. I installed the channels first time. I have freeview channels except I cannot get the Sky channel to show?
When you say you have freeview channels, and then say you cannot get Sky channels this is not enough information that you have provided, but
I presuming in addition to freeview channels you also have a Sky Satalite receiver which is no longer connected to your Tv or your sons tv Either way Sky satalite have 2/4 lines which means you can have four viewings providing multi rooms is bought from sky, and additional boxes are fitted.
Or you can have 1 sky box main Tv and no the spare cable feed at the back of the sky box you can feed another cable to another tv from that same box but it will be same channels But you can now change channels using magic eye receivers etc, in any room.
But the question I believe is you had freeview but no long can receive sky channels the information is a little vague but hopefully I have helped a little
Sep 05, 2017 | Bush Televison & Video
I would like to find out the TV code for my 55' Bush tv so I can programme my sky TV remote please.
Hi Darren, I have Sky (foxtel) and the Sky box (foxtel box) is hooked up to my television and the only thing is i turn the volume up to full on the television and control everything (volume and change channel) through my Sky(foxtel)remote control..... I hope this helped, CHEERS..
Mar 31, 2016 | Bush Televison & Video
It says I need code to get some stationd
This could be caused by your channel receiver picking up a new channel, like a scrambled sky channel.
Do you have a standalone receiver like, MYSky or Free-view, Dish TV or similar.
These usually scan for new channels occasionally and find channels that need codes or are scrambled.
Maybe you have a content lock on the TV to prevent the viewer from accessing some channels.
Feb 11, 2014 | Toshiba 65HM167 65" Projection Television
My tv's freeview wont let me view any other channels apart from the bbc
Freeview? I'm not good with tv words... Is freeview a free channel you stole from the neighbors dish (don't be ashamed)? If so, then you should buy cable (Cable's better. Really. Satellite dish companies looked one thing over. Storms ruin your tv.). If your just watching what you can get through the air, well, that won't work. After a while, you start to lose channels. Just get cable. If you already have a tv network, then you should call the tv company.
Jun 18, 2012 | DMTech DM-AV10 Digital Media Player
Sky is saying there is no signal. Turn box off and on again. I have done this but still get no signal. I have freeview only channels on my sky box
Firstly, you don't get Freeview through your Sky box. If you are watching Freeview channels then it's from an aerial connection. If you are getting a 'No signal' message on your TV, the first things to check are:
1. Check that you have selected the correct input source on your TV. If you are using a 'co-ax' connection (standard aerial cable) you will have to select this manually from the remote. If you are using a SCART connection, all you need to do is turn the Sky box off and back on - but you've done this already.
2. Check the connection from your Sky box to your TV - disconnect it, check that the cable and connectors aren't damaged then re-connect it.
3. Check the cable between the dish and the Sky box. Unplug this from the Sky box and reconnect it.
4. Check that your viewing card is correctly inserted. This is unlikely to be the problem as it doesn't usually result in a 'no signal' message, but remove it and re-insert it anyway.
Finally, it's very windy tonight and this can affect the Sky signal if your Sky dish isn't properly secured. It's possible that your dish has been moved by the wind and is no longer aligned with the satellite. If none of the above work, you should inspect the dish as soon as conditions are safe enough to do so. If you can move it by hand, it can probably be moved by the wind.
Try these tests and post back and I will try to assist further if the problem has not been resolved.
Regards,
BElectric
If your problem has been solved, please be generous and award this solution 4 thumbs-up. This service has been provided FREE - your simple acknowledgement is appreciated. Thanks.
Nov 09, 2010 | Televison & Video
Hi I purchased a Sony 60 inch T.V model KDL60EX703U. It is supposed to have built in free view. I have set it up the same as my previous t.v however when searching for channels it does not find any. ...
When you are searching for channels check what setting the channel search is in this model had DVB-T DVB-C and DVB-T2, If it is in the wrong search mode it will not find the channels. Also does your sky decoder use a dish? if yes then this could also be the issue as the TV uses Terrestrial signals and the SKY decoder will use a Satellite System.
Oct 25, 2010 | Sony Televison & Video
Tuning sony tv model kv28dx30u Automatic tuning is a complete failure manual tuning fids some channels but a message appears stating that no digital programmes are available. we do not have freeview but do...
If possible, instead of hooking up the TV using RF cable (standard cable) and viewing the TV through channel 3 (or 4) hook the TV up using audio video cables (RCA type yel.,red and wht.) and hook them to the video input of the TV.
Dec 08, 2009 | Televison & Video
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
Sky
Oct 12, 2008 | Televison & Video
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
