Question about JVC GR-D73E Mini DV Digital Camcorder
E03 eject and reinsert tape: Unit in SAFEGUARD MODE - what's Adix that means?
welcomejee
  • 10594 Answers
SOURCE: my cam is GR-D93 the error
E03 error shows problem with tape loading mechanism, eject the tape and look for pinch roller is in its place or not. Usually pinch roller came off from its position and tape can not be drive.
Pinch roller is small round part, made of black rubber that helps the capstan motor to drive tape in forward or reverse order.
Thanks.
Posted on Sep 28, 2010
SOURCE: Can't play or record because of error E03 on display
I GOT
Posted on Aug 30, 2009
  • 115 Answers
SOURCE: keep getting E03 error indication. Ejecting and
where your battery goes in,on the side , theres a little hole should say reset,get a niddle and push it and after you reset it ,it should work,make sure its on when you do it .if my info is of any help to you please leave me a comment ,thankyou.
Posted on Sep 02, 2009
kala
  • 156 Answers
SOURCE: GR-DVL320 keep getting E03 error indication.
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
Posted on Sep 12, 2009
welcomejee
  • 10594 Answers
SOURCE: JVC GR-DV3000. Goes to
If camcorder accepts normal MiniDV tape without any problem and you can record or playback it correctly then please try another brand video head cleaning tape as existing head cleaning tape might be not good that is why camcorder rejects it.
Hope this will help.
Thanks.
Posted on Mar 30, 2011
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
MY CAMERA SHOW E03 ;unit in safeguard mode ;EJECT AND REINSERT TAPE WHT SHOULD I DO............
JVCGR-D270.Digital Camcorder. When we put the tape in the cam it chews the tape whiles loading and says that it's in 03 safe guard mode. Please help.
Jan 24, 2011 | JVC GR-D73AG Mini DV Digital Camcorder
It is writing: unit in safeguard more eject and reinsert tape. However after reinserting tape it does not correct. Please help.
Safeguard mode follows a numeric code, go further down and you will see. In case "02" you need a service personel (something to be done/parts need to change with the mechanism)
Feb 28, 2010 | JVC GRD250 MiniDV Digital Camcorder
Keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
Sep 02, 2009 | JVC Cybercam GR-DVL520 Mini DV Digital...
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
Unit stuck in safeguard mode
I can't find e setup for sony
camcorder
Dec 30, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Unit in safeguard mode
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Mar 29, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC GR-D73E Mini DV Digital Camcorder Logo
1,031 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
