Question about ViewSonic VA721 17" LCD Monitor
Sorry help me. I am looking the diagram for connector vga from lcd VA 721 VS 10047. The connector that i have has: 1. red, 2. grey, 3 blue. LCD manufactured in 2004 Thank you
  • 11,361 Answers
PM me for service manuals that may help you, budmrtn@aol.com
Posted on Dec 29, 2010
Vga onboard
you may have encountered a VGA cable not properly installed to the VGA ports....try to reconnect the VGA cable,properly installed from the VGA port of the LCD to the onboard VGA port of the motherboard and restart computer... less pressure applied to each and every end of VGA connectors to VGA ports may sometimes affect the display of the screen causing to red, pink blue screen output....hope this help...
Dec 30, 2013 | Intel DH55HC Motherboard
Need a hp part number for a lcd display for a HP Pavilion dm4t-1200 laptop.
I would like you to try using HP's Part Surfer.
1) Put your Product Number, or Serial Number in the Quick Search box,
(P/N = Product Number.
S/N = Serial Number.
{DO NOT give out the serial number on a public forum such as this. Only on the HP website}
2) Then click the blue down arrow on the right side of the - Select a country or region - box, and click on your country.
3) Finally go back to the Quick Search box, and click on the side arrow to the right.
Post back in a Comment as to your findings.
We'll go from there.
On the back of the LCD screen is the HP part number.
http://www.screentekinc.com/HP_Pavilion_DM4T--14-inch--1366x768-wxga_hd-laptop-lcd-screen.shtml
{Scroll the page down, and see if any of the 36 part numbers may be a match}
Display LCD screen replacement instructions,
http://www.insidemylaptop.com/disassemble-hp-pavilion-dm4-laptop/
http://www.insidemylaptop.com/replace-lcd-screen-hp-pavilion-dm4-laptop/
Awaiting additional questions. Please post in a Comment.
Regards,
joecoolvette
[ P.S.
You can disconnect the LCD display, and use an external VGA monitor, while you wait for the replacement LCD screen.
1) Laptop off, VGA monitor off.
2) Connect the VGA monitor to the Left side of the laptop.
( External monitor port. The VGA connector resembles this one,
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
3) Turn the VGA monitor on. Wait for it to 'warm up'.
Turn the laptop on.
If the display does not automatically go to the external monitor;
Press, and hold down on the Fn key.
Tap the F4 key.
(The VGA monitor can be a CRT monitor, {Looks like a small TV}, or a flat LCD screen monitor that has a VGA connector, and a VGA cable ]
Sep 04, 2011 | Computers & Internet
Vga wiring i want to know what each coler wire represents so i wont burn my pc wiring my stuff into it
Here's some wiring diagrams:
First according to pin: http://hot-flash-games.com/web/vga%20cable%20pin%20connection-2875.html
And in this post you have pinouts according to standard color: http://www.diyaudio.com/forums/diy-projectors/30458-vga-pinout-wire-colors.html
db15 male
1)brown
2)red
3)orange
4)salmon
5)yellow
6)dark green
7)light green
8)dark blue
9)NC
10)light blue
11) purple
12)grey
13)white
14)black
15)brown/black
DB15 Female
7)light green
2)red
11)purple
13)white
1)brown
6)darkgreen
8)dark blue
10)light blue
3)orange
that's all oh yes you also have a ground wire from connector base to connector base.
Hope this helps. So from these two, you should be able to figure out witch wire is witch. Let me know if you need more detailed information.
May 03, 2011 | VIA ASUS A8V-E Deluxe K8T890 chipset...
Hitachi Plasma model P50V701 - press the POWER button, display lights go from standby-red, to Power-blue to blinking blue and the sound and picture appear for about 2 seconds. have tried unplugging and...
(Green Power LED will go Green the Go Off) Brief rise then collapse of the Vs and Va voltages.
This indicates a "Load" on the line.
Pull the CN-64 connector feeding Vs/Va voltages to the X-SUS.
Take an ohmage reading from the Va and Vs lines on each PWB.
This means you have to read the Connector on the Power Supply and the pulled connector going to the X-SUS.
See if there is a low value. Low value indicates a defective PWB.
Normal reading should be infinity. (Using the diode mode on the DV/Voltmeter, there will be a brief charge
time, then infinity.) In other words, it may appear as a low ohm reading, but should rise to infinity or open.
(Also not, if there is a charge on the line, the meter may show a low. You must Pull the CN68 connector and take
a reading again).
The line should now be infinity when reading the Power supply pins for Va and Vs and when reading the
connector going to the X-SUS PWB.)
If a Low is see on the connector, pull the CN32 Connector. (Bottom right hand plug on the Y-SUS PWB)
Jan 12, 2011 | Hitachi P50V701 TV
Schemas cable VGA monit. Philips 107
1)-red
2)--green
3)--blue
4)--ground
5)--ground
6)--red(ground)
7)--green(ground)
8)--blue(ground)
9)--+5v from vga card
10)--stand by
11)--synchronus ground
12)--serial data
13)--Hsync
14)--Vsync
15)--serial clock
Mar 28, 2010 | Fujitsu Siemens 38B1 (White) 15" LCD...
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
Scheme for the VGA Cable of Acer AL1511eb
You will have to buy a 13 Pin Din Male Connector cord. Use the break-down below to help with reconfiguring.
Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 N/C Not connected Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 +5 V +5 V DC Pin 10 GND Ground (VSync, DDC) Pin 11 N/C Not connected Pin 12 SDA I²C data Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 SCL I²C clock
Nov 24, 2008 | Computers & Internet
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
4&5 Not connected
9&10 NC
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
HP 1702 monitor pin-outs
Okay...after a bit of trawling the net I found an almost correct pin out. It was not identical to my broken connector however after a bit of checking, I found that all the screens on the cable were common so I wired the connector as follows and all was well! :- 1 Pink 2 Grey 3 Light Blue 4. Violet 5. Link to 6,7, and 8. 6. as above plus a link to the drainwire next to the foil screen. 7. Link to 8,6 and 5 8. Link to 7 and 6 - just use some solder! 9 Dark Blue 10. Red 11. Black 12. Brown 13. Orange 14.Yellow 15 Green I used a diecast 9 way backshell and tied the cable braid screen to that so everything properly screened. Plugged it in and away it went! Hope this is helpful in the future. Best regards Victor.
Apr 26, 2008 | HP L1702 17" LCD Monitor
No video
can you still see the menu? if not your problem is either the power supply or the y-sustain. check the va and vs from the power supply. the voltages are listed on the back of the panel on a grey sticker. if you have these voltages then replace the y-sus
Oct 11, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
ViewSonic VA721 17" LCD Monitor Logo
59 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
