Question about Zojirushi CD-LCC50 Electric Kettle
I just poured water from the electric kettle and discovered LOTS of lime deposits. Scrubbing didn't get all of it. What can I do to clear out the lime (I'm assuming that's what it is - looks like salt). lhurst@gannett.com
  • 25 Answers
Fill it with vinegar and leave to soak overnight/for two nights if really bad.
Any parts which are impossible to fill with vinegar - lids/spouts, soak a cloth or tissue in vinegar and wrap/wedge into....and leave to soak overnight.
Posted on Jan 16, 2011
  • Anonymous Jan 16, 2011
What are the advantages of using clear glass kettle?
Clear glass kettle are attractive, easy to pour from, and refill because of its large top opening. You will find many good functions on the advanced clear glass kettles like Breville and Cusinart. Cleaning the scale deposits from the inside is easy and much more.
Get some more details here: Top 5 Best Electric Kettle
Jul 28, 2015 | Kitchen Appliances - Others
How do i clean the inside of illuma kettle
You can use Lime-Away (at Home Depot) or Apple Cider vinegar. It seems to work much better then regular vinegar. In either case let it boil if it has no element inside the water compartment, put a small clean rag inside and use a wooden spoon to clean the heavier areas. Boil it a few times, then dump it, and boil and clean with clean water twice, then put it back in service.
Feb 26, 2015 | Morphy Richards Illuma 43121 Cordless...
The lining of the kettle on the inside bottom is boiling away. What is it made of and is this dangerous?
Stainless Steel doesn't boil away. What you're seeing is the mineral deposits (mostly calcium) left behind from heating the heavy water you're pouring into the kettle. Descale it, pour it out and rinse every month or when it gets bad if you like. These deposits won't hurt you but looks nasty. Another option is to use filtered water instead of tap water. Hope this helps a little...
Oct 17, 2011 | Oster 5965 Electric Kettle
My Breville kettle does not beep anymore when the desired temperature has been reached.
Might not work, so don't cuss me if it doesn't, but have you tried demineralizing it? Pour it full of white vinegar, let it heat to about 160-180 and then turn it off and let it soak for a couple of hours. The vinegar will dissolve any mineral deposits on or in the heating system. Mineral deposits are the bain of electric water heating systems of all types. Drip coffee makers, 95% of the time, a premature ***** is due to mineral deposits. It also destroys house hot water heaters.
Aug 27, 2011 | Breville BKE820XL Electric Kettle
We have a black@decker stainless dome kettle (red) electric kettle. we've used it for a couple years and it works great, but there are deposits inside basin that we can't get off with soap/water. they're...
Jan 01, 2011 | Black & Decker Black Decker Brushed...
How do I remove limescale from inside an elecric kettle?
You could buy in any grocery shop and in the net any brand of KETTLE and THERMOS DESCALER! Just put it in ur electric kettle and leave it for a day, it will disslove those lime scales! Taah!
Nov 12, 2010 | Morphy Richards 43072 Cordless Electric...
I have noticed black water deposits at the bottom of the pot, and want to clean them out. What do I have to do? If I have to buy some tablets or other aid, what is it and where I can get it? Thanks.
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Aug 29, 2010 | Oster 5965 Electric Kettle
How to clean the inside of tea pot (scale deposits)?
Vinegar is very good at removing scaly deposits. Heat white/clear vinegar just as you would normally heat the water for your tea. After heating the vinegar, pour out and rinse thoroughly with water. If there are still deposits after this first attempt, use vinegar once again. Once you are satisfied that all the deposits have been removed, heat water in the tea pot 2-3 times to remove any smell or taste from the vinegar (before using for tea).
Jul 07, 2010 | Breville "Ikon" Tea Kettle Electric Kettle
HOW DO YOU REMOVE ALL OF THE BROWN RESIDUE FROM A BRAUN WK200 KETTLE?
There are comercial products that will do this look for it in houseware stores, maybe some big Ace Hardware stores, maybe even at your chain grocery stores.
Feb 26, 2009 | Braun WK200 Electronic Water Kettle...
Siemens porsche kettle on/off switch problem
Hi
Make sure that the lid is securely on. Otherwise its the replacement of the auto bi metalic strip which turns the kettle off
Feb 14, 2009 | Breville SK500-XL Stainless Steel Cordless...
Zojirushi CD-LCC50 Electric Kettle Logo
161 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
