Question about Whirlpool Duet GHW9150P Front Load Washer
Flashing error code F20 - Whirlpool Duet GHW9150P Front Load Washer
  • 1,772 Answers
Wer
Sorry to read about your problem, I hope this helps you out.
F20" on display
(Water Inlet Problem-no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
Check the following:
1. Are water faucets completely turned on?
2. Are screens at inlet hose connection to washer
clogged?
3. Are water inlet hoses kinked?
4. Are water inlet hoses frozen?
if this issue's are ok you may want to contact a service company
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire ples389ece range
http://www.frigidaire.com/support/ResultsPage.asp?strModel=ples389ece&User=&Search=Search
That website has a manual for your Range and it should explain the F20 code.
I'm gonan look through the manual and check out what F20 means so ill be back in a bit.
Jan 20, 2008 | Frigidaire PLCS389DC Dual Fuel (Electric...
OUR HUMIDIFER IS FLASHING F20 AND IT WONT RUN WHAT NEEDS TO BE DONE?
Owner's manual, Troubleshooting. Otherwise Google Make Model possibly serial number year and your error code. You may get lucky. Otherwise MFG customer service, usually they are helpful.
Mar 04, 2015 | Washing Machines
How to fix F20 error code whirlpool duet
How to fix F20 error code whirlpool duet YouTube
https://www.youtube.com/results?search_query=How+to+fix+F20+error+code+whirlpool+duet
Sep 04, 2014 | Whirlpool Washing Machines
Start the load on normal wash and F20 will show up the load will remain flashing F20
"F20" is a "No Water Detect" error code. This usually means you have very little water entering the machine, or no water at all. The following link explains the error code in more detail and steps necessary to troubleshoot:
http://www.fixya.com/support/r3608632-f20_error_code
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: Each one of thes washers comes with a technical data sheet inside. The tech sheet lists all error codes, troubleshooting information, wiring diagrams, diagnostics procedures and illustrations. To access, you need to remove the lower toe panel directly below the door. The screws are located under the bottom front edge. With the screws removed, the panel will drop down and can be removed. If the tech sheet is not located directly behind the toe panel, it will be affixed to one of the interior cabinet walls.
I mention the tech sheet, because you may need to refer to it in order to accurately troubleshoot.
If you have any questions, please post back and let me know. I hope this information is helpful to you.
May 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
MAYTAG 3000 SERIES JUST RECEIVED AN F20 CODE. WHAT DOES F20 MEAN? THE MECHINE RAN FOR 10 WASHING THE STARTED STOPPING ABOUT 10 MIN IN TO THE CYCLE WITH F-20 FLASHING.
need the correct model # and ser # _ _ _ 3000 _ _ _ _ this tell us age and and fault codes . now inside the machine / you will find a tec sheet with the codes . this may be quicker .. mm
Dec 02, 2009 | Dishwashers
No water is running in to washer and display F20 flashing
These things have an awful reputation for F20 errors. Take a look at http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore (Not written by me, but I just came across it) for some advice
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
244 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
