Question about LG Washing Machines
LG front loading washing machine model WM2455HG will not drain water out. I do hear a humming noise. In the proces of trying to figure out best way to access pump for testing ohms through winding then bench test with voltage or obstruction. I did remove filterand cleaned At first thought I thought there was a problem with spin cycle. However, I then drained water level with washer on then spin cycle started. Have any recomendation on how to remove pump? Don't want to mare surface removing panel...thanks, Burt
SOURCE: Washing machine has intermittent drain issues with F02 code
When the three screws are out of the bottom, you should be able to pull the front panel down (towards the floor) and then out from the bottom. Unscrew the big white cap on the drain housing. Be prepped for the water. Most of the time the problem is due to **** in there.
Posted on Sep 24, 2008
  • 899 Answers
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
this is an error that indicates the tub is clogged or draining slowly
to fix this you have to go under the washer and pull the tub hose off and clean all obstructing stuff in the hose and thru the hole on the tub
Posted on Oct 18, 2008
  • 2920 Answers
SOURCE: Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Posted on Feb 07, 2009
MNfisherman
  • 11896 Answers
SOURCE: Need to remove the front panel of front load washer
you will have to remove the rear panel in order to remove the front panel. The bolt and clamp are inside the front panel.
Posted on Jul 09, 2009
  • 10865 Answers
SOURCE: Need to buy drain pump for LG washer WM1812CW but
Hello. you can order the LG parts from any home depot.
Posted on Mar 08, 2010
My LG washer is not draining, I have OE code. Is there way to test the drain pump with out having to fill the drum/washer with water?
Hi if you remove the pump again get a plug and wires example from a table lamp and attach 2 wires to the pump dont worry about polarity it will run both ways plug into the wall see if the pump runs out of the machine ( does this model have 2 pumps one could be the recirculation pump)
Dec 27, 2014 | LG WM2016CW Front Load Washer
My drain filter is filling up with water
Have you checked the filter for obstructions? Some objects can end up near the pump intake and reduce or block the flow. Loose change is one item that I have seen in a filter.
Oct 06, 2014 | LG WM2455HG XL Front Load Stackable...
How can I spin and drain my normal size load. I have an LG front loading washer m/n WM2455H and it will not spin and drain. I hear the hum of the pump, so it isn't that. Went through all troub
It is most likely the drain motor even though you hear it humming. The LG drain motor impellers usually wear out on the motor shaft, and the impellers then just end up wobbling. The result; a drain motor that no longer drains water.
Sep 13, 2014 | LG WM2455HG XL Front Load Stackable...
Front Loader LG Inverter 7.5kg model WM-12330 FB On the last wash it wouldn't drain the water away. Tried 'drain' programme and rinse & spin programme - all works normally till it needs to drain and...
Have you already check your drain clean out? If it's not draining, you'll need to manually drain the washer, via the small hose that pulls out, once it is drained you can unscrew the large clean out filter, and see if anything is caught up in that area.
If all that is clear, it's most likely, you'll need a new drain motor. Also, did you notice if your getting a "OE" error code on the display?
Feb 28, 2011 | LG WM-2277HW Front Load Washer
Doesn't seem to be draining water out after the rinse cycle. Just seems to make a humming noise.
Have you checked the pump for blockages? very common on these machines and has symptoms as you describe. Try blowing back down drain hose while it is humming (be prepared for a possible rush of water)
Oct 25, 2010 | LG WM-1832C Front Load Washer
Water pump hums and then doesn't pump out water, the machine keeps saying OE, but there is nothing stuck in the filter. Is the water pump bad or maybe a relay?
get a shop vac and try to **** water out through the drain hose, if water comes out at least you know your drain hose is not restricted, if you can get all the water out you may have something inside your pump not letting the impeller turn, especially if you can hear the pump humming, Drain water out and open unit up to check pump for restriction
Aug 22, 2010 | LG WM1814CW Front Load Washer
I need a service manual for an lg wm2455hg front load washer. Where can i get one?
i have thiswm2455hg unit that is to me worthless it doesnt wash the cloths clean i just go through the cycles and the cloths come out spots and not clean it vibrates on spin clycle the cloths look drye when the machine is washing very little suds this is the last front load im getting let me see the agitator in the water not this front load clonker and it stinks after sitting a couple days whats up
Jun 09, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Turns on makes weird humming noise
The noise is most likely your drain pump trying to clear water from the sump area. If you remove the bottom screws holding the lower access panel in place, look for the drain pump and a block rubber hose connected to it. I suspect there is something preventing the pump from draining all the water. Remove the clamp holding the hose to the pump (have towels handy as there will be water) and clean out the sump, then put it back together and give the washer another try.
Mar 08, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
116 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
