Question about Whirlpool Duet GHW9150P Front Load Washer
This morning I found water all over in front of washing machine. The door was open and it was spilling out from inside. The tank inside was full of water also.
  • Whirlpool Master
  • 8,220 Answers
You must have a bad water inlet valve This morning I found water - themobilian_606.jpg
Posted on Dec 29, 2010
Mold growing
If you mean on the outside of the machine, there is probably a slow water leak, and it is soaking the floor which is making to much moisture.
If your talking inside the machine.
Try and wash by hand the machine with a 50/50 bleach/water/ and a 1/4
cup dish detergent.
Run the machine through a full wash cycle, with a 1/2 gallon bleach
in a small load setting,
Then run the machine with full load setting and nothing for detergent, just the water, say three times. To flush all the cleaning you did away.
From now on leave the door open when done so if there is any water or moisture inside it does not stagnate.
Feb 08, 2010 | Frigidaire GLTF2940ES Front Load Washer
Washer will not spin out water but turns during wash cycle
Try cleaning out the trap. It is located under the door and can be accessed be removing three screws at the base in the very front of the washer. The trap is white and screws to open. Watch out though, because if the washer is full of water it will come spilling out! With the trap removed, you should also use your finger to feel the opening of the pump to the side. I found a few bobby pins in my pump, and once they were removed it worked again!.
Jan 08, 2010 | General Electric WBVH6240HWW Front Load...
Water accumulated in drum while machine off and door open.
The water valve may not have closed completely or may be leaking. You can copy and paste this link in your address bar for more great repair info and feel free to ask any other quesitons:
http://home.howstuffworks.com/how-to-repair-a-washing-machine3.htm
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
Water fills up in machine when off
HI thanks for your question. i would replace the water valve, its not shutting off completly. replace the valve, thats where the hot & cold water go .
Oct 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water accumulates inside the washer
i guess you have washer drain pipe plumbed into a spigot on the sink trap. if so, when you empty sink, some of the water goes down the washer drain pipe and ends up filling your machine.
to cure, take the drain pipe as high up as possible under the sink in a swan neck and that should cure it. its a common problem
Jul 22, 2008 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Can you add clothes to washer after cycle starts?
Not really. Even if it lets you it will pump out the water first. This kind of defeats the purpose. If it didn't pump out the water it would spill on the floor.
Jul 03, 2008 | LG WM2688H Front Load Washer
Door opens
faulty catch or switch interlock
Oct 18, 2007 | Maytag Neptune MAH6500A Front Load Washer
Washer door pops open during wash cycle
Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
Oct 06, 2007 | Maytag MAH6500 Neptune Front Loading...
Whirlpool Duet GHW9150P Front Load Washer Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
