Question about Maxtor 160GB OneTouch III Mini USB 2.0 External 160 GB Hard Drive
Connected Maxtor 760GB 1 touch 4 plus to my DVR USB port and I can not get it to work. It lights up and I do get something on my TV screen saying that it is there, but can't get it play back and I know there is data on the disk. I set up the ERD on the tv, but no results. Help
SOURCE: maxtor one touch iii not recognized
Does Windows recognize that there is anything plugged in at all?
If not it could be your USB interface (on the Maxtor) is shot.
Posted on Dec 10, 2007
SOURCE: Maxtor One Touch 4 Plus
I have the installation program. You can contact me
Email: haulingkc@yahoo.com
Tony
Posted on Jul 12, 2008
SOURCE: maxtor onetouch 4 mini usb 2
You cannot download drivers/software for the Maxtor Mini at the above URL. When you select the Maxtor Mini, you're redirected to a contact form you have to fill out just to get the software. Pretty lame on Seagate's part! I'll think twice before purchasing anything else from them.
Posted on Aug 28, 2008
gotgeek2
  • 565 Answers
SOURCE: Maxtor One Touch 4 is beeping when I connect it by usb
Is this a new drive or have you been using it for some time and it just started doing this? What make/model computer do you have?
Usually when they start beeping like that, it's an indication that the drive is not getting enough power. It's possible that you are plugging into unpowered USB ports. Try using the USB ports that are directly connected to the motherboard (the ones in the back.)
Use USB 2.x ports if they are available. Try connecting the drive to another computer.
Posted on Jan 28, 2009
SOURCE: my maxtor one touch mini just stopped working.
Dear,
Please check it on the different computer with the same USB cord.
Regards,
Rakesh Kumar
Posted on Apr 01, 2009
Maxtor one touch 4 plus will not power on even after replacing power supply
Have you tried it in different outlets? Is it also connected to your computer via the USB cable while it is plugged in?
Aug 27, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
How do i find a usb adapter for my maxtor one touch 4 mini 120gb it broke?
You can buy a USB to USB mini cable at almost any store with PC accessories, even Walmart. Buy a high quality one since the drive is powered from the USB 2.0 port. Good Luck
Jul 23, 2009 | Seagate Maxtor OneTouch 4 Mini 120GB...
Vista is not picking up my maxtor harddriver but wheni had xp was .
Check the disk management MMC - it's likely that you have another drive letter that is conflicting with the Maxtor.
1. Right Click on the Computer Icon (or in the menu),
2. click on Managment,
3. look for Disk Management(on the left side) and click on that.
4. This will show you all the installed HD's that you have.
Your main HD is probably called Disk 0. IF there are any other HD's listed they will probably be labled "removeable", if it doesn't have a drive letter assigned to it do the following:
1. Right click on the Disk (X) that does not have a drive letter. (it should be a "Removable Drive")
2. Select Change drive letter and Paths.
3. Choose a drive letter from the list that is not used, I suggest W or Z just to be sure.
4. After you do that it should come up in My Computer as an available drive.
IF the External Drive is not listed then you need to change the USB port or try it on another PC to see if it works there.
May 30, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
Maxtor one-touch mini won't appear on PC
To isolate the problem, please try the steps below:
1. Make sure that the USB ports of your PC are working.
2. Try to connect the device into different USB ports.
3. Try to connect it into different Windows based computer.
Question: Did you reformat this device using your Mac? If yes, there could be a possibility that the device was reformatted using the Mac OSX (Journaled). This type of format would only recognized by Mac computers.
But if it's formatted using the DOS based system, it would work on both Mac and PC.
Apr 01, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
Jan 28, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Does the HDD spinup?
My slightly educated guess... the Ext 2.5in HDD requires more power than it is getting from the single port.
1. Try another port
2. Try it on another computer (all USB ports do not provide 250ma to a load)You may be sharing this avail voltage with all plugged in devices and will have to pull 1-2 others to get the HDD online. Since STARTUP current is high, the HDD pulls all it can from the ports (logical) then settles down and uses 1/3 to keep spinning. After the HDD is up and online, try plugging the other USB devices back in, 1 at a time. If it stalls the HDD - you know the why
3. Take it back and find something a bit less power-hungry (Like Hitichi or Toshiba)
Jan 16, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
MAXTOR ONE TOUCH 4 MINI
Try it in another computer if you have one. Or...try it in another USB port on your desktop PC. I would see if it appears in the device manager. If so, and you don't get a drive letter, try running
'diskmgmt.msc' and looking to see if the drive pops up under available drives.
Jun 01, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Maxtor One Touch 80 Gig Drive
Go into the device manager and clear the USB ports.
Apr 19, 2017 | Maxtor One Touch (RBAY080B0USR) Hard Drive
Maxtor one touch mini doesn't appear to work.
The blinking light indicates something is happening to know open :
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=1600
And check the power cord and try with the known good power cord.
You can check this :
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=4996&p_created=1194886713&p_sid=SzkLKr3j&p_accessibility=0&p_redirect=&p_lva=1600&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTg0LDE4NCZwX3Byb2RzPTQxMCw0MjEsNDYxLDQ2NSw1MDgmcF9jYXRzPSZwX3B2PTUuNTA4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*&p_li=&p_topview=1
Good Luck.
Live, Love, Laugh.
Feb 16, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Maxtor 160GB OneTouch III Mini USB 2.0 External 160 GB Hard Drive Logo
113 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
