Question about Toshiba Satellite p105-S6114 Notebook
Power cord doesn't make good connection, feels like something is loose inside. Please help
  • 600 Answers
Its probably the dc jack--common problem on laptops--needs to be resoldered--takes about 1 hour
Posted on Dec 29, 2010
Spectroniq tv doesn't turn on, lights off.
The fuse is inside--power cord should go almost direct to it--beyond that if fuse good is power supply for the set.
Nov 06, 2012 | Televison & Video
Frigidaire AC Window, Model # FAC107P1A2
please leave the unit unplugged from the main power for few hours and check if it works
Jun 29, 2008 | Frigidaire Heating & Cooling
Do not know how to connect power supply
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Unplug all electronic cords connected to the computer.
At no time during the installation should any cords be connected to the computer.
Remove the screws holding the computer cover case, and remove the cover case.
Locate the computer power supply box, which looks like a large box out of which a bundle of wires run and connects to the power cord jack on the outside of the computer case.
Unplug the power cables from the internal devices connected to it.
Be careful not to damage any of the sensitive control boards or devices inside the computer, and be certain to remember--write it down if you need to--what devices will need reconnecting to the new power supply when you finish the installation.
Unscrew the power supply from the inside of the computer case and remove it. Check the original power supply's red voltage switch for the correct setting.
It should read 120 or 240 if you live within the United States.
Confirm this setting as the correct voltage setting for your power outlets.
Make sure your new power supply gets set to the correct voltage setting before you install it.
If it cannot be set to the correct voltage, do not proceed with the installation or you may damage your computer.
Return the new power supply and buy one that is compatible with the voltage requirements.
Install the new power supply, reattach the screws that will hold it in the proper place inside the computer.
Reattach the power cables that come from the new power supply to the devices that were connected to the old power supply.
Make sure all of these connections are firmly in place before you turn the computer back on.
Reattach the computer power cables and all the cords connected to the computer during normal operation, but do not close the computer case yet.
Keep your hands clear of the inside of the computer case as you attach power cords and peripheral devices.
Turn the computer on and observe the performance of the computer without touching anything inside.
Do all the computer fans function normally?
Does the computer operate as well as or better than before?
If you feel that the computer behaves normally and you do not encounter any problems, turn the computer off, remove all the power cords and peripheral cables once more, and close the computer case.
Then reattach the power cords and peripheral cables and begin using the computer.
Check for errors if you encountered any problems starting the computer or if it would not start at all, unplug all the power cords and computer cables connected to the computer and look inside.
Make sure that you connected all the correct power cables inside the computer securely and did not miss any.
If you have confirmed this and the computer still doesn't start or operate normally, call your computer manufacturer or a professional computer repair shop for assistance completing the installation
http://www.youtube.com/watch?v=xvClS_M-09o&feature=watch_response_rev
watch video
hope this helps
Oct 10, 2012 | Computers & Internet
Power cord is shorting out
The cable guy may have bumped the power connector and loosened it. Try pushing it in firmly. Sometimes the power connections get loose over time
Oct 03, 2012 | Toshiba Televison & Video
No power
Dear Sir:
The Not power can have many reason, plase do the following:
1)Reset the c. breaker from your house(the breaker that control your outlet where do you have connect the treadmill)
2) Please do the same with the breaker from the treadmill
3)Inspect if the treadmill inside after the transformer has FUSE.?
4)Inspect your power cord.
5) Do not use extension cord power if you are using.
6)Smell if you feel something burn?
7)Retight the wires from power cord, and inside from Treadmill.
8)If there are some wires loose or making colder joint.
9)See if there are corroded cables?
Attached is my design for block diagram, for easy troubleshooting.
2_14_2012_7_47_34_pm.gifSincerely. God bless you.
ernesto a cuadra
managua, nicaragua. c.a
Jan 07, 2012 | Exercise & Fitness
My sony klv-32u100m won't power up, is there something i should check?
Verify that the power cord works with something else (like a computer monitor) while it is plugged into the same outlet. I've seen power cords pull loose when a cat stepped on them, or break inside under stress, particularly when people pull them by the cable instead of the plug.
If that is good, you may have a failed power supply. Do you want to get inside the set for a visual inspection? If so, post back for directions on what to look for, and when you do, please indicate whether you know the difference between a transformer and an electrolytic capacitor.
Oct 16, 2010 | Sony BRAVIA KLV-32U100M 32 in. LCD...
ZV5120 pavilion notebook powercord not connecting
You can get an exact adapter from eBay link below, they are quite cheap. Sometimes the break is close to the end of the plug, and sometimes, the actual solder on the socket inside the unit is fractured, causing intermittent connections. Often we are able to use the old cord Plug, and graft on the new power Lead. However it is wired and regardless of how many wires are inside, the is only One - Negative, the OUTER contact. The INNER Contact is Always + Positive, sometimes there are three wire inside, TWO are Plus, and ONE, the shield, is negative.
http://shop.ebay.com/i.html?_nkw=HP+Pavilion+zv5000+power+supply+&_cqr=true&_nkwusc=HP+Pavilion+zv5000+power+supplly&_rdc=1
Mar 15, 2010 | HP Pavilion zv5000 Notebook
Power jack feels loose and the computer shuts off
good day, you may want to buy a new power cord or replace the power terminal. hope this helps, have a nice day
Feb 08, 2010 | Toshiba Satellite M45-S169 Notebook
No power to the computer
Check this link:
http://h10032.www1.hp.com/ctg/Manual/c00246219.pdf
Jan 30, 2009 | HP Pavilion ze4560us Notebook
Cyberhome portable DVD player 700-B
It sounds like there is a connection inside the dvd player itself. If you feel comfortable taking it apart you will prob. see if there is a missing connection.Hope this helps!
Feb 02, 2007 | Cyberhome CH-LDV 700B Portable DVD Player
Toshiba Satellite p105-S6114 Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
