Question about Kenmore Elite HE4 Electric Dryer
The controls on the right do light up when clicked however it just clicking sound and not running
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
I am unsure as to when several of the problems I am having began, such as Windows Media Player now only running as administrator. After setting up the LogiSys SP6006CL LED speakers the LEDs would not light...
there could be many problems causing you sound problems
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Sep 23, 2011 | LogiSys SP6006CL Clear 2.1+1 Multimedia...
My Bose Companion 3 speakers are not turning on, the light on the control panel does not turn on. I am curious how I can fix this issue or tell if my sub has power running to it.
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if you dont have a motherboard disc you will have to download the drivers
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
hope this helps
Sep 06, 2011 | Bose Companion 3 Computer Speakers
No sound on HP 1140n desktop computer NO audio
enable the o board sound card from bios
Mar 23, 2011 | HP Computers & Internet
When i start my 2001 civic lx there is a clicking sound coming from the passenger side dash and engine light goes on and off. after it stops the car doesn't run right.
Check engine light usually means a problem with the
emissions control system. At any rate Honda is your
best bet. They will have to hook up and look for fault
codes. Clicking sound could be a relay.
Feb 12, 2011 | 2001 Honda Civic
My computer doesn't register this device at all. The output is working to my speakers and the power light is on but that's all. Someone in my office suggested that I need to update my USB drivers?
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 27, 2011 | Behringer (UCA202) Sound Card
What's wrong with my acer 4741? the sound is very low. I have adjust the sound level to the highest level. but it still doesn't work. please give me the suggestion
INSTRUCTIONAL STEPS
  • Click the "Start" button on your screen, then click on the "Control Panel." Double click on the "Sound and Audio" icon.
  • Click the "Place Volume Icon in the Taskbar" option to have it in the lower right corner. Click "OK" to save your settings.
  • Check your volume icon to make sure it does not have a red-and-white mute button around it.
  • Move the mouse click to the volume icon, then right click the mouse. Click on the "Open Volume Control" option on the pop-up menu. Remove the check on the mute button under the master control, if it is checked.
  • Move the volume slider in the master category upward. If you begin to hear sound, then the problem has been resolved.
  • Click the "Start" button on your screen, then click the "Run" option to check your Windows audio service. In the run window, type "services.msc" then click "OK."
  • Scroll down the list in the services window, then right click the "Windows audio option." Click on "Properties."
  • Select the "Automatic" option under the "Startup" tab, then click "OK." Test the sound. Try using headphones into the phone jack to test the sound
  • Click the "Start" button, then select the "control Panel" to check sound drives. Double click on "Sound and Audio" devices, then click the "Audio" tab.
  • Check the correct sound default device on your laptop under the "Sound Playback" option. If you installed other volume drivers on the laptop and you don't know the correct default, consult your user manual or contact the manufacturer.
  • Click the "OK" button ,i hope you"ll find this helpful,remember to leave your by saying how helpful this post is
  • Oct 07, 2010 | Computers & Internet
    No sound at all when start up orage mute light
    Try to follow the following steps;
    1. Start, then Run, then enter REGEDIT to open the Editor
    2. Navigate to the HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class entry
    3. Under the Class entry, double click on {4D36E965-E325-11CE-BFC1-08002BE10318}
    4. In the right-hand pane, click ONCE to select the UpperFilters entry
    5. Make sure the UpperFilters entry is highlighted, press Delete, then Yes.
    6. In the right-hand pane, click ONCE to select the LowerFilters entry
    7. Make sure the LowerFilters entry is highlighted, press Delete, then Yes.
    8. Close the Registry Editor by clicking File, Exit.
    Regards,
    Anirban Mazumdar
    http://www.ikarmatech.com
    Sep 09, 2009 | Compaq Audio card Sound Card
    Sond problem
    Please make sure speaker should not mute and it should be contect with correct port and power trun on
    Please try to follow these steps :-
    1- Try to start WINDOWS AUDIO services from services.msc
    just type services.msc in run command and start the windows audio services.
    if not resolve then
    2- Try to go
    • Click Start, click Run, and then type devmgmt.msc.
    • Right-click My Computer, click Manage, and then click Device Manager.
    or
    • Type the following command at a command prompt: start devmgmt.msc
    then check the SOUND, VIDEO AND GAME CONTROLLERS
    if there is any yellow and red mark on any device then delete that device.
    then restart the system.
    3 try to update the driver :-
    1.Right-click My Computer.
    2.Click Properties.
    4.Click the Device Manager tab.
    5.Click a listed device and a new window will open.
    6.Click Drivers to see what drivers are installed on your computer.
    7.Click Update and Windows will see if you have the latest driver.
    3- uninstall the sound driver from the devmgmt.msc or
    More likely you'll have to go to [Control Panel > System > Hardware > Device Manager > Sound, video and game controllers > (Your sound card) > Driver > Uninstall],
    a reboot will almost certainly be required.
    Then reinstall the software.
    May 05, 2009 | Intel Motherboard
    My lenovo S9, I can hear any sound.what should I do... before it has a sound,but when I re install ( I hv a virus on my netbook s9) and the sound dissapeared....
    right click on my computer -->properties-->device mngr-->sound video game controlers: right click on your audio device and update drivers
    Apr 23, 2009 | Lenovo Thinkpad T60 Notebook
    Kenmore Elite HE4 Electric Dryer Logo
    27 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal De
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
