Question about Danco 89448A Universal Toilet Tank Lever, Chrome with White Porcelain Handl
Does it matter if the replacement tank lever is plastic or metal? We have a water saver toilet (2004) and the current lever is plastic.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
Nope just the metals will last longer
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
The toilet tank does not refill automatically once the lever is pushed and the water flushes out of the tank. In order to get the tank to fill with water again after the toilet is flushed, I have to take...
Just replace the whole assembly. It only costs 12-15 dollars. Water contains so many minerals that just clog up lines like cholesterol. Just be done with it. It is not worth the effort to try to clean all that out . Plastic is sometimes not very forgiving.
Jan 28, 2013 | Toto Drake ADA Compliant Toilet with...
I just installed a Sterling Wyndam two piece toilet, and water is leaking from the three bolts in the tank. It seems to be coming out between the plastic sleeves the bolts go through and the holes in the...
Try checking to see if you got the gaskets that around the plastic things in correctly.Often a part is in upside down or in the wrong order (IE bolt washer metal washer instead of bolt metal washer washer)You can make sure that the bolts are tight enough to compress the gasket but do not tighten them to much, you will crack the toilet.
Jun 07, 2011 | Sterling 402315-0 White Windham Two-Piece...
Our single piece Kohler toilet does not flush clean. It appears to not be using enough water quick enough to give a clean flush. The tank level is just above the white line on the over flow pipe level so...
The flapper on these toilets is a water saver. The water saver flappers can be replaced with a standard flapper and I have found this will help considerably. The flapper is located in the tank at the center bottom. It is the part that flaps up and down when you pull the lever.
May 09, 2011 | Kohler - Toilet - One-piece - San Raphael...
The water will not refill! The inner plastic part doesn't work and it's only one year old! I must pour a bucket of water into the bowl to flush waste.
Does this tank have the plastic bucket around the flapper inside the tank. If so this is a water saver toilet. A few tricks to increase the water. I have had to remove the bucket by cutting it maybe half into to increase the gpm.
This will increase it to more than 1.6 gpm's. It can be cut down just be careful in doing it if this is the problem.
Next make surethe fill valve has line running and attached to overflow tube. This will fill the bowl with the needed water for it and the tank.
Next make sure the water is set to the mark either on the tank or the overflow tube. If no mark to within 5/8" to top of overflow tube .
Jun 27, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
When I flush my mascerating toilet, the tank behind the toilet floods over. How do I fix this?
I assume you are referring to the holding tank and not the pump case.
The bowl float system on the couple SaniPlus toilets I have seen are similar to standard toilets. This will be a plastic float that slides up and down the water inlet tube. It will be attached to a shut off lever at the top of the tube by a metal rod. The float and rod are attached to each other by a "V" shaped clip. To adjust the shut off level you need to slide this clip up/down the rod.
If you remove the top of the tank and flush you should be able to see this working when flushing. Try shutting off the water flow by moving the shut off lever by hand. Use the water shut off at the inlet line leading into the tank to start and stop the water before it over flows if the lever does not work.
If the lever does not stop the flow then you have a problem with the water inlet mechanism and it may need to be replaced.
If your inlet mechanism is different from what I described please respond back with the model number of your SaniPlus.
Hope this helps.
Jun 22, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
I just installed a Kohler Wellworth toilet. Wheni flush the tank only empties about 3 or 4 inches and then shuts off. The water level is at the highest. How do I correct this. Thanks
As long as this toilet is NOT a pressure assist toilet. Then it probably has a water saver flapper that you can replace with a non water saver flapper. This will allow it to flush more. Be advised you may have to adjust the water level after the change to prevent it from double flushing. Hope this helps.
May 21, 2010 | Home
Toilet lever doesn't rest horizontally in the bowl
bend the arm on the float in the toilet tank and this will change the handle position
Oct 29, 2009 | Danco 80806 Metal Toilet Tank Lever,...
The toilet sometimes will continue to run after flushing
the chain should have some slack to it being too tight it dose let the flapper sit properly so itll keep running because water is escaping
Jul 03, 2009 | Danco 89448A Universal Toilet Tank Lever,...
Danco 89448A Universal Toilet Tank Lever, Chrome with White Porcelain Handl Logo
88 people viewed this question
Top Danco Home Experts
Donni Steen
Andrew Bugbee
richie46
Are you a Danco Home Expert? Answer questions, earn points and help others
