Question about LG 26LD350 26 in. TV
How do I activate the usb on 26 ld 350 - LG 26LD350 26 in. TV
231 service call error 03
https://www.youtube.com/watch?v=5C2KAer0818
Mar 14, 2016 | Oki Printing Solutions C511DN LED Printer...
I have a Sharp LD-26SH3U 26. I have picture but no sound. I turned it off to go to work & when i came home it took awhile to even get picture, then the picture came on, but no sound.
A couple of thoughts here--you may have suffered a power loss while away--unplug set for a while and then power back to see if it helps.
As far as the sound it is unlikely but possible the speakers may have got switched off somehow--check in audio or setup menu to see if this is the case.
Apr 17, 2012 | Sharp LD-26SH3U 26 in. LCD Television
Obtain Tuner Activation Code Serial Number: 6200Y04102884
Westinghouse.com/support then go down and click tuner activation put your serial number in to your right and hit enter and you got a code
Dec 05, 2010 | Westinghouse Electric LD-2655VX 26 in. TV
Hı sc 322 laser unut problem ld unut end laser connector poor cable error
Hello sir; Sometime this problem can be reset, just let's try, ; Press " clear mode ", "107", "stop/clear" key until screen show out sp mode then turn power off and back on again.
Oct 11, 2009 | Ricoh Aficio 1035 Copier
Sharp LD-26Sh3U menu locked
RELEASING THE ADJUSTMENT LOCK
Perform this procedure using the buttons on the TV.
1: Turn off TV
2: While pressing the "MENU" button press the "POWER" button continue to press the buttons until "UNLOCK ADJUSTMENT" appears on the screen.
3: Press the "VOL >" button.
That's it you may have to turn the unit off then back on at the end of step #3.
May 18, 2009 | Sharp LD-26SH3U 26 in. LCD Television
Docs and media onto a LifeDrive with Vista
The problem is that the Palm desktop sfotware that works with the LD doesn't work well with vista so you need to do things a bit differently.
I copy files to sdcards if they are say movies or music in otherwords big or lots of files as it is faster. If I want to copy my documents to the ld hardrive simply plug the LD into the usb data cable and then turn on drive mode. Vista will now recognize your ld as just another flash drive or usb drive device. Copy the files to the hardrive or even the sdcard if its in the slot. You can create your own directories in either place so it is easy to know where your files are.
May 14, 2009 | Palm LifeDrive Handheld
Need this part
I get a lot of boards from a company called Vance Baldwin (www.vancebaldwin.com), and they sell Sharp parts. You might also try a Google search for the part number.
Nov 21, 2008 | Sharp LD-26SH1U 26 in. LCD Television
A Sharp flat-panel that doesn't read inputs and responds slowly.
I have the same tv. and the same problem.
I am able fix other LCD problems.
But this one is a bit harder.
I will try changing all the capacitor and let you know if this works
Jul 03, 2008 | Sharp LD-26SH1U 26 in. LCD Television
LG 26LD350 26 in. TV Logo
237 people viewed this question
Computer Repairing
Computer Repairing
