Question about Apple A1082 CINEMA DISPLAY 23" LCD Monitor
When connecting my a1082 monitor to a PC nothing happens..what might be the problem? I have used an adaptor to make the plug physical compatible with the laptop.
  • Bud Martin
    Bud Martin Dec 30, 2010
    Does it work with PC desktop? You have the connector with DVI now right?
4 Suggested Answers
  • 1481 Answers
SOURCE: Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Posted on Jan 04, 2010
c-tekk
  • 177 Answers
SOURCE: nothing comes up..after connecting it to my laptop
Try using the menu on the monitor
to change the input mode (much like changing the input channel on a tv).
also make sure that your pc display settings are set correctly.
Posted on Mar 04, 2010
budmrtn
  • 11361 Answers
SOURCE: how can i fix my apple model a1082
What kind of problem do you have? Any error code from the front LED?Common problem with this model is due to bad VR3 3.3VDC Regulator.See more pictures here:http://s807.photobucket.com/albums/yy352/budm/MAC%20Monitors/MAC%20CINEMA%20HD%20Display%2023%20inch/
Posted on Jan 21, 2012
Model A1082 monitor remove stand
http://manuals.info.apple.com/MANUALS/1000/MA1096/en_US/073-0933.pdf
Aug 17, 2014 | Apple A1082 CINEMA DISPLAY 23" LCD Monitor
Can someone help me a circuit diagram for the apple 23" HD monitor
http://tim.id.au/laptops/apple/displays/cinema_hd_display_23.pdf
May 26, 2012 | Apple A1082 CINEMA DISPLAY 23" LCD Monitor
How can i fix my apple model a1082
Dec 28, 2011 | Apple A1082 CINEMA DISPLAY 23" LCD Monitor
Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Mar 24, 2011 | Computers & Internet
My studio 15 laptop isn't turning on, so I'm using my sister's laptop to try to find a way to turn it on but nothing is turning on at all!
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adapror and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
If the adaptor is fine then you have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Nov 04, 2010 | Dell Studio 15 Laptop
My monitor is in sleep mode and I cannot wake it up. I will press the power button on the side of the monitor and will get an occasional brief light to go on in the lower corner of the monitor frame. I...
May be it's he pc that's in sleep mode, try some keys on the keyboard to wake it up or try the function key plus f8 a couple times. Depends on what your setup is. Is there a other viewing hardware connected?
Mar 08, 2010 | Apple A1082 CINEMA DISPLAY 23" LCD Monitor
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
2 RAM is corrupted
No power to moniter
This kind of problem needs an isolation. Please try the steps below:
1. Check the physical connection and make sure that the power cable is properly seated to the monitor.
2. Connect the monitor into different power outlet.
3. Try using different power cable.
Otherwise, you need to bring your monitor to the repair shop if none of the steps help.
Have a great day!
May 09, 2009 | HP L1702 17" LCD Monitor
Compaq Presario 700 Series Laptop wont turn on
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Nov 23, 2008 | Compaq Presario 700 470024-192 Notebook
Apple A1082 CINEMA DISPLAY 23" LCD Monitor Logo
286 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
