Question about RCA DRC8335
It won't play DVD's. It'll say it's loading, but then it says no DVD is not found. I need help!!!
  • antpat2745 Dec 29, 2010
    I did all that. The problem is it stopped working about a year after I bought it. I'm going to check it tonight to see if theres some sort of reset button. I spent too much money on it to just die on me. Thanks for the info.
  • 40 Answers
Check the disc(s) for scratched. Try a NEW DVD (movie). If that fails, you have issues with dust on the lens. You could try a lens cleaning disc but they are not all that good.
Posted on Dec 29, 2010
Won`t play dvd`s.try a cleaning disc no luck!possible dvd diode gone?any help please.Nigel...
Hi Nigel,
There are three reasons for discs not playing.
First, if the set has been lying for some time, the loading belt becomes lose and the loading is not complete. The result is no disc play.
Second, there is dust on the lense. Again the result is no disc play.
Third, the lense unit has gone bad or weak. Here also the result is no disc play.
Jan 24, 2016 | Televison & Video
Why won't Castleville load on Zynga.com, I don't even get the bar. It will load on Facebook, but I'd rather play on Zynga.com. Please Fix.
The website is most likely undergoing changes or fixes. If you wait a while it may work again.
Jul 13, 2012 | zynga.com
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Compact Disc rewritable DVD player won't load or play
Check the data connector on the rear of the drive. If this doesn't work you may need a new drive, they are cheap and readily available.
Jan 19, 2012 | Lenovo Computers & Internet
No matter what DVD I load in the player, it won't play the DVD. It says "Cannot play this disk". What's the problem?
The first thing to try is to clean the laser itself by using a cleaning disc. If that fails then most likely the pickup laser is no longer any good. This is usually obvious if you place an audio CD in the unit and it plays fine : )
Jul 27, 2011 | Sony DVP-FX750 Portable DVD Player
Cant play a region 1 dvd
The DVD and *and* the DVD player both have a region code embedded in each. A map of the regions used appears below:
Regions 0, 7, 8 & 9 do not appear as they represent "No Region Coding" "Unused" "Cruise Lines" and "Region Free" respectively.
A DVD player will only play a matching region code DVD, or the player OR DVD have one (or more) 0, 7, 8, or 9 region codes imbedded. You'll not be able to change the DVD code, but you *might* be able to change the region code of your player. Computer DVD players can sometimes be flashed to a new region more readily than the entertainment system DVD players, but it relies solely on the manufacturer and model of the player. Some require file be downloaded and run, while others require a DVD or CD be created and played with a specific file saved on it. Here's a link to results that discuss how to change the region code for DVD players. You'll need to know at the very least the manufacturer and model number of you player to begin.
I hope this helps and good luck! If you found this helpful, please rate my reply 4 "thumbs up". Thanks!
Jul 12, 2011 | Audio Players & Recorders
My Sony CDRWDVD CRX880A ATA Device won't read Dvd's I'm trying to make burn a movie on there and it won't load the disk it says " Let windows help me choose a disk" because D:/...
The
CRX880A is a cd writer and DVD reader it doesn't record dvd only plays them
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 03, 2011 | Sony CRX880A CD-RW/DVD-ROM Combo Drive
I cant get the tv to go through the surround sound i can only get the surround sound to play when its a dvd playing do i need another wire to go from the dvd player or will it not work no matter what plz...
If you've got the Audio Input Source set as TV-Audio and it won't play as Surround Sound then you'll need to connect the Audio Out from your TV (if it has one?) to the Audio AUX IN on your LH-T360SE and change the Audio Input Source to AUX.
Jun 04, 2011 | LG LH-T360SE Theater System
My new homefront ps3 will play on my friends playstation but will not play on mine help
If it won't play online what you'll need to do is set a static ip in your router for your ps3 and then open ports TCP Ports: 80, 443, 5223, and 10070 - 10080
UDP Ports: 3478, 3479, 3658, and 10070
(you'll need to contact your router about that)
If it won't play AT ALL follow these steps ( http://us.playstation.com/support/answer/index.htm?a_id=1488 ) to get into safe mode and select option 3.
If NONE of your PS3 games work and NONE of your blu rays work, your blu ray drive is fried and you'll need to get it fixed. You can go to: us.playstation.com/getservice to get it fixed.
Mar 21, 2011 | THQ Homefront PlayStation 3 for...
DVD Player does not work
General Problems
Player won’t work (locks up)
• Try unplugging the AC power cord and plugging it back in.
• Reset the DVD/VCR: on the front of the unit, press and hold the STANDBY/ON button while you press and hold the STOP button—wait at least 3 seconds
before you release both of the buttons. You’ll need to set up your menu preferences because this Reset Procedure returns the DVD/VCR’s menus to the
factory default settings and also erases the contents of the Disc Library.
Mar 15, 2008 | Televison & Video
RCA DRC8335 Logo
48 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
