Question about Maytag Neptune MCE8000AY Electric Dryer
We have a neptune dc that will not heat up. would also know how to take it apart?
    President:
  • 1,194 Answers
When the dryer won't heat it is the thermostat/thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help....
Posted on Jan 01, 2011
How do you take apart a maytag neptune dc dryer
When you open the door. The hinges on the door have phillips screws, take them out. On the other side are two tabs with phillips heads screws, pull those out. After the removal of the door, grab both sides and gently pull torwards you. Lift it off and set it to the side. After this you will have alot of 5/16" drive screws. Remove those and take the two plates off, dont forget to remove the to wing tabs at the top that hold the lid down. Hope this helps.
Thank You
Kurt
May 29, 2012 | Dryers
Gas dryer neptun DC does not heat and dry cloths
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 04, 2010 | Dryers
My Neptune washer is showing error code dc..once it starts the spinning cycle the machine will stop.
See if my Clutch Fix post will get you started if your machine model type is a FAV6800A or FAV9800A.
Service Manual for reference. Sears Parts Direct for reference.
Your TDS is working or the machine would shake itself apart.
If you decide to DIY I will help you thru the process. If you decide to have it repaired show the Clutch Fix post to the repair tech it will help him help you back into service......Rich
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
May 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune dryer dc is heating but is not spinning
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 06, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Error code of "dc" on my TL Maytag Neptune
If your machine is FAV6800AW or FAV9800AW the dc/UC errors are caused by a clutch malfunction. Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed.
Fix the Clutch malfunction and you can wash a single sock or a load of blue jeans and you will not take the dc or UC unbalance errors. See this post for the fix.
Post back if you have questions or need help.
Rich
Oct 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Apr 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune dc
I have a Maytag Neptune drying center. The top unit is making a very loud banging noise. How can it be repaired, is this a common problem?
Apr 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune DC Model# MCE8000AYW leaks water from the right side of drying center unit while using the "Wrinkle Release Hanging Dry Only" feature. The leak happens during the steam portion of the cycle....
Stop using the water bottle because the water is overflowing the heater steamer pan and will short the heating element and the part is no longer avaliable and the top will stop drying.
Mar 27, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
206 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
