Question about RCA D52130 52" Rear Projection Television
Leaked out coolant on red tube
Unfortunately it allowed the tube to fail in a big way. I have not been able to locate a replacement tube. Any ideas where I can look?
  • 4,234 Answers
Any RCA parts distributor should have one. The part # is: 256844 with a cost of $280.05.
Hope this helps,
Dan
Posted on Jul 07, 2008
A few weeks ago I had the upper hose go on me. It had a hole in it and leaked out all my coolant. My husband (while helping change the hose) gave it a big **** and ended up cracking my radiator. I had that...
Hi, you wern`t clear on the year and model of your Honda, and was the radiator and hose replaced by a sevice shop or yourselves? Possible causes of your car overheating may be caused by not ``bleeding`` the air out of the cooling system properly. Another problem may be a malfunctioning thermostsat, another problem may be the Electric rad fan not cycling on. There could be a few more causes but I would have to know more details of your car as mentioned above..
Feb 22, 2011 | Honda Civic Cars & Trucks
Oil from lences leaked out and got on al the chips and wires what do i do
This is projection tv coolant. You need to clean all region on board where the liquid leaked and remove the tube who leak and flush the coolant. after good cleaning of tube and lens, reassable them and refill with new coolant.
Apr 22, 2010 | Sony KP-53HS30 53" Rear Projection...
The coolant leaked right out onto the ground, the pump is working
Those cars have big problems with the intake/intake gaskets leaking, and water pumps. When you find the leak, repair and flush with coolant other than dexcool as this is the source of most of the cooling issues on GM cars.
May 30, 2009 | 2004 Pontiac Grand Prix
Coolant is leaking onto circuit board and shorting it out
Glycol leaks can be a problem. How bad is the leak is it dripping on the boards. This stuff that s leaking is called glycol conductive anc corrosive. keep the set upluged. The seals in the crts have failed. they would have to be replaced. Very involed repair. it involves removing the tube and removing the glycol removing the seal cleaning the tube replaceing the seal refilling the tube putting the tube back in and aligning. at the shop such a repair is about 2 to three hours..if THE GLYCOL has leaked on the board then the board could have been damaged. AT this point you have to ask if it is worth it. always get a profesional to do this type of repair. i dont say this often but this is not a fix it yourself
Mar 18, 2009 | Sony Televison & Video
PIONEER ELITE PRO730HD 64in Red lens lower assmbly losing fluid
You'll need to replace the red CRT . The coolant chamber of the original tube has been compromised. Hopefully, none of the fluid( ethylene glycal) has leaked onto the main chassis of the TV.
Feb 10, 2009 | Televison & Video
60 inch philips big screen, fluid accidently drain out .
Yes you sure can , call electronixs 1-800-223-3205 ask for projection fluid/high purity.
Dec 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Need new green picture tube
You dont need a new tube. What you need is to repair the seal on your old tube and replace the CRT coolant fluid. There is a coolant chamber attached to the tube with long bolts with springs on them that contains coolant to prevent your tubes from getting hot. Yours may just need tightening, but I would replace the seal just to be safe as thecoolant can and will destroy your circuit board if its allowed to continue to leak on it.
Jan 15, 2008 | Samsung HCL4715W 47" Rear Projection...
No red, orange, pink or green color!
Sounds like your green tube is low or is bad
Mitsubishi > VS XXXX
this model is famous for fluid leaks. each projector True True (``````````` (``````````` 0 95250 95250 clip_image002.png tube has a reservoir on the front of it with a fluid in it. this keeps the face of the tube cool.
this depends on how bad the damage is in the tv. in most cases we can reseal the tube and clean up the fluid 400-600.
Once you
take the tube out you will see where it leaked. The problem is that the
frame on the CRT that the heavy screws with springs are mounted on (that
hold the lens coupled to the CRT) is weak and they can bend. We have seen
several that have leaked after the customer moved the set. You can only
tighten them down so much because the frame bends. It is just stamped metal
and not welded at the corners to support the bend.
We remove the CRT, clean it all up, add a very small amount of RTV sealer to
the gasket, reassemble, let the RTV cure thoroughly and refill with coolant.
The extra sealer should prevent future leaks. Haven't had a recall yet.
Mits says replace the CRT...too costly.
You msut check the yokes carefully as well. If any coolant gets into them
you can end up with shorts there and a mess.
Clean the boards carefully and repair any corrosion damage. The coolant is
ethylene glycol and glycerine which is water soluable.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
1998 mitsubishi big screen model VS-50603
this model is famous for fluid leaks. each projector tube has a reservoir on the front of it with a fluid in it. this keeps the face of the tube cool.
Once you
Jan 12, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Replace the green projection gun
I have almost the same problem, but it was with the blue CRT tube. The coolant leaked onto the underlying PCB and caused short-circuits and sparking or arking. I purchased an exact replacement PCB for the CRT, but I suspected most of its coolant had gone, so I need to re-fill the coolant for the blue CRT to stay cool.
Dec 01, 2006 | RCA Scenium HD65W20 65" Rear Projection...
RCA D52130 52" Rear Projection Television Logo
75 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
