Question about Coby Televison & Video
I received a 15" Coby
  • 40 Answers
Couple things; You have to "program" the set to receive the analog channels your cable system is still sends out. Doubtful it will be too many. You may have to rent a set top box from them.
Posted on Dec 29, 2010
Closed caption is on and neither the remote nor the menu setup options for cc are working. I tried resetting to factory settings but no help. Advice?
Search Results
    [PDF]Instruction Manual
    static.bhphotovideo.com/lit_files/62319.pdf
    TFTV1525 ... If this equipment does cause harmful interference to radio or televisionreception, ... The LCD panel used in this television contains millions of thin film transistors that ... 15. or cable system during a lightning storm or when it is left unattended and ..... There are four options lised under the Closed Caption menu.
    COBY TFTV1525 INSTRUCTION MANUAL Pdf Download.
    www.manualslib.com > ... > Coby Manuals > Flat Panel TV > TFTV1525
    COBY Electronics TFT LCD Widescreen Television Instruction Manual. ... Cobyelectronics 15" widescreen lcd hdtv/monitor specification sheet (1 page) ... Operation is subject to the following two conditions: • This device may not cause .... Direction &OK While working with the system menu, press the direction buttons to ..
Jan 13, 2016 | Coby TFTV1525 15 in. LCD TV
TFDVD 2284
Coby tf-dvd2284 LCD TV Repair Questions,... - Fixya
www.fixya.com/support/p1341165-coby_tf_dvd2284_lcd_tv
I have a Coby TFDVD 2284 want to get off cable & use the free tv stations. How do I do this ... Coby Flat Panel... ' Answered ... 22 inch coby flatscreen won't start.
I have a Coby TFDVD 2284 want to get off cable & use the ...
www.fixya.com/.../t23676249-coby_tfdvd_2284_want_get_off_cable_a...
Feb 27, 2014 - I have a Coby TFDVD 2284 want to get off cable & use the free tvstations. How do I do this ... Nov 24, 2014 ' Coby Flat Panel Televisions.
Coby TV Parts - ShopJimmy
www.shopjimmy.com/coby
ShopJimmySearch all of our Coby TV parts and find the correct part for your Coby TV repair.
Coby TFDVD2274 - 22" LCD TV Manual
Dec 21, 2015 | Coby Televison & Video
White space above and below picture
Thirteen Retailers Recall 32" Coby Flat Screen Televisions ...
www.cpsc.gov/.../Thirteen-Re...
U.S. Consumer Product Safety CommissionDec 12, 2013 - This recall involves black Coby 32-inch flat screen televisions with model number ... AmTRAN Video Recalls to Repair 42-Inch JVC Flat Panel ...Missing: space
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the ... Just match up the sticker, and also add a space and n8lk, then search on amazon. .... LCD & LED TV Repair - No Image & BlankBlack Screen Flashlight Test ...
Coby DVD-209 Ultra Compact DVD Player Troubleshooting ...
https://www.ifixit.com/.../Coby_DVD-209_Ultra_Compact_DVD_P...
iFixitNot Compatible With Coby DVD Player; Disc Types Compatible; Problem Message Displayed On Screen. "WRONG ... Follow the repair guide to replace the fuse inside the device. ... The same goes for the white and yellow plugs and ports.Missing: space
Top 139 Complaints and Reviews about Coby Electronics
www.consumeraffairs.com > Electronics > Televisions
Dec 21, 2015 | Coby TFDVD2284 22 LCD TV
Coby tv wont turn on but has power
unplug it, hold power button for 30 seconds plug it in. does it work? if not test outlet. does outlet work? if so... tv needs repair
Feb 18, 2015 | Coby TFTV3225 32 in. LCD TV
When powering on my Samsung 55 inches LED TV, the middle/bottom light panel just flash/blink and there is no picture on the TV screen dark/black screen. I would have to let the TV on for 1-2 hours to
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 06, 2015 | Samsung Televison & Video
Coby tv will not turn on
Check and replace the main power regulator board.
Jan 24, 2013 | Coby TF-TV3217 32 in. LCD TV
No red led on front panel & wont power on at all
Check the wall outlet to see if you have power going to the TV. Next, the case will need to be opened; look inside for a fuse near the power wire. Beyond that you will need someone with TV experience to help you.
Jan 12, 2013 | Coby LEDTV2226 22 in. TV
Tv won't turn on
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 27, 2012 | Coby TFTV3225 32 in. LCD TV
Coby 32 in TFTV 3229 sounds terrible
Aug 21, 2012 | Coby Televison & Video
My Coby LEDTV-2426 24 No Power
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 19, 2012 | Coby LEDTV2426 TV
Televison & Video Logo
131 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
