Question about Dryers
I am changing the belt..what size do i need? - Dryers
  • seth adams Dec 29, 2010
    need exact model number
  • Dryers Master
  • 7,482 Answers
It will depend on what dryer you have, you failed to mention what dryer it was for.
This website you will find a belt replacement for your dryer: www.partselect.com
Posted on Dec 29, 2010
Replace belts on realistic sct-30
I can't tell you how to change the belt on your model though I have changed many belts...
Some belts are fairly straightforward to access and others are more like a torturous route march but once the belt has been accessed, the next problem is identifying the belt cross section and diameter.
Buying a belt from the manufacturer as a spare part is likely to be expensive and often difficult as the trade generally prefers to obtain replacement belts from a general component supplier meaning the manufacturer needn't keep any stock.
Replacement belts are listed in diameter of length size increments and cross section shape and size. If you know the size of belt needed, ordering is easy but belts begin to stretch from day one so measuring the old belt would be useless and using string or a tape around the pulleys also useless.
Typically a new belt of the right size must be stretched to fit around the pulleys - some considerably and some not as much and mostly by how much smaller the new belt needs to be is pure guesswork, consequently it usually pays to order a selection of sizes and choose the one that provides the best result.
Before fitting it is well to remove all traces of residue and oil or grease from the pulleys and to slightly abrade any highly polished driving surfaces with something like Scotchbrite.
Mar 15, 2017 | Audio Players & Recorders
How do I change a power steering belt and what size is the belt?
all different sizes as not all cars/trucks are the same check with your auto parts store .they will be able to tell you how to change also
Aug 05, 2015 | Cars & Trucks
Belt for Power steering needs changing> belt size and how to change
would need more information for your request year make model and engine ----go to any auto parts store they will ask same information for belt ---if serpentine belt under hood is a diagram of how belt is routed use a breaker bar or ratchet on tensioner pulley remove belt on older thin belt usually loosen alternator remove belt replace tighten alternator
Need size of the deck belt toro 212.5 wheel hourse
the size of the belt would change with the size of the deck
Jul 02, 2012 | Toro Garden
Hi, I need to change my serpentine belt but my other belts are looking kinda rough, so I think I'm just going to change them all. Looking online I noticed different sizes for the belts for my 1995...
Firts of all don't get a belt on line, go to the auto parts store and get one there, They can match up old belts and also look up the correct belt for your car. You need to know what year and size of the motor and what els you have that is belt driven like Ac and power steering and such. If you take your old belts in they can match them with what is in the book to make sure they are right and you don't have to worry about getting the wrong belt.
Oct 10, 2011 | 1995 Lincoln Town Car
I need help on how to replace a ford 99 model super cab fan belt and what size belt would I need... also can I tighten the head gasket with a shifter.. cluless? ? Thank you. Carryn
First to get right fan belt you tell folks at parts store year, make & model & engine size and they look it up for you. To change belt depending in which belt you have to loosen alternator, power steering pump etc... bolts and slop old belt off new one on and retighten. (Parts folks can show you how also) If you have a bad head gasket, they need to be replaced not tightened.
Mar 31, 2011 | Ford Ranger Cars & Trucks
My 1993 mtd lawn mower will not get out of reverse
the belts are the wrong size,you may need to get the next size up.go to partstree.com put in your model #.it should be able to tell you what size you need.hope this helps
Jun 12, 2009 | Mtd Garden
Waterpump belt
you have a serpentine belt, which is one belt drives all, so the routing of this belt is very specific also it matters whether or not you have a/c. Locate your belt routing chart under the hood before beginning. There is a tensioner pulley mounted on a spring arm, the spring arm should have a square drive hole in it, either 3/8" or 1/2" drive size you will need a ratchet of the proper size to insert into this square hole. Using the ratchet move the tension arm (away from belt) to loosen the belt and remove, route and install the new belt and move tensioner the same way place the belt over it and release. Hope this helps, let me know
May 16, 2009 | 2000 Ford Contour
Need to replace belt on Eureka Powerline 12.0 vac. Screws look like Torx head or something on bottom of vac. Are those the screws that need to come out for changing? If so, what size do I need?
No, do not remove the torx head screws for a belt change. If there are any screws that need to be removed for the belt change, they will be phillips head. What is model # of vac??
Oct 04, 2008 | Eureka Vacuums
Bissell vaccum cleaner belt change
I need instructions on how to change the belt
Sep 09, 2008 | Bissell 3522 PowerForce Bagged Upright...
Dryers Logo
26 people viewed this question
Top Dryers Experts
