Question about Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT
Jandy Model LJ125N Hot Tub Heater: One year old unit, it attempts to fire then atuomatically goes into a FL6 error code. This unit has had a recent Natural Gas Valve replaced on 12/26/2010 Electrican has no clue on what to replace on this unit....... so my question is , do we need to install a different gas valve or replace the Power Module Board ??????????? or both thanks, Shane
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Check wiring if wired 120 volt turn power card to 120 volt
Posted on Sep 25, 2014
  • 990 Answers
SOURCE: Jandy 'Lite 2' 325 btu "LG" Natural gas unit will not fire up!!
You have to make sure the heater is wired for 110v where you hook the wires up to it. Depending on model it has a red and a black and a red tracer and a black tracer wireyour leads hock to two and the other two wire nut together It will have a tag or scematic to tell you how in a couple of places on the unit. If not that it will simpley be a plug that pulls out in one place and plugs in another. On the early units of that model it may be you just need to reverse polarity also. One more thing if it is a forced draft (with an internal fan) It is imperetive that you gas meter and gas line are sized correctly or it won't fire at all.
Posted on Oct 04, 2009
SOURCE: Jandy Lite2 Pool heater will not stay lit after firing.
Aside from the other suggestions made here... make sure you have the inlet, and outlet pipes from the heater routed properly. If you have them backwards, the unit will fire, then kick off shortly after.
Reason for this is because the unit kicks off when the water temp at the inlet reaches a specific temp, if they are swapped, it's measuring the water it just heated, not the water coming back from the pool/ spa. Make sense?
Posted on Mar 05, 2010
thepool
  • 78 Answers
SOURCE: Describe your Jandy Laars Lite2 Pool
A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. See manual for details. C. Replace igniter.
Posted on Apr 22, 2010
SOURCE: where can I get a internal diagram of a Jandy 3
try searching for spares on poll equipment sites they should have diagrams for you to id the parts required Riverwade
Posted on Dec 17, 2010
UglyPoolGuy
  • 46 Answers
SOURCE: my jandy valve drips in the off position but stops
It sounds as if when the valve is in the "off" position it may be causing a build up of pressure on the valve. When the valve is "on" the water is nit restrictes and the bwck pressure is reduced to a point that allos thw valve to operate without leaking. the fix may be as simple as replacing the orings. Generally, a rebuild kit will cost $15.00 and can be installed by most homeowners. If that does not solve the problem, the valve may be worn out and need to be replaced. Over time, the holes that the screws around the top screw into just wear out to a point thqt they cannot be fully tightened.
Good luck and if you need to purchase a new valve, or would like to try a rebuild kit, call us at 602-74-3880.
Posted on Feb 03, 2011
Ignition lockout code
what is the error code in display, did u reset the board by turning the power on/off
Jun 09, 2013 | Legacy Jandy Lrz250en Swimming Pool Spa...
Insulation gone in Jandy Lite 2
need new heater that one is unsafe
Jun 02, 2013 | Jandy Pool & Spa
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
Jandy lite 2 pool heater. The heater is about 5 years old. Pool and hot tub share the same water supply side. Heater started shutting off at lower and lower tempatures over the last few months. Heater...
if you have not been keeping the water balanced, there may be a buildup in the pipes inside the heater core. this would cause the heater to work harder, produce less heat transfer and cause the over temperature sensor to kick out before meeting the set point.
Apr 01, 2017 | Pool & Spa
JANDY HEATER FL6 ERROR CODE
check safety circuit and pressure switch
Jun 18, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
Our Jandy LX400N does not show any error messages but the water that comes out of the jets is intermittently hot, then cold. I have never heard of a hot tub problem like this. Is there a way to just have...
check gas pressure maybe running out of gas then it goes out then relites check to see if heater is running continuously bad manual bypass replace it by the plumbing in and outs
May 23, 2011 | Jandy Laars Lx 400,000 Btu Heater
My service light is on and I have a bO code. The heater will run some times, more time than not it will not run. Thanks Dave
The bO code is a normal code. It stands for bypass operation and just means that the heater is wired into an automatic controller such as a jandy or aqualogic. If there is a call for heat and the heater doesn't fire, you should be getting an error code. It may take several (3 or so) attempts at firing before you will get the code. HTH
May 15, 2010 | Hayward H400idl2 400,000 Btu Low Nox...
Hi Limit Switch error
this may be for two reasons first the water is going to slow make sure filter is clean and either the water inlet plump incorect or the valve assembly is damage and need to be replace the high limit is letting you know the temp is getting to hot inside the heat exchanger
Jun 06, 2009 | Jandy Laars Lt 250,000 Btu Heater
Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Logo
141 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
